Schneider Euro PC
Reply 100 of 125, by dr.zeissler
Thx, how do I install the XTIDE-Bios in the IDE Slot? Have you done this before?
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 102 of 125, by Jinxter
dr.zeissler wrote on 2021-09-14, 20:09:
I while ago i saw a XTIDE BIOS ISA Card on https://www.tindie.com/. But i could not find it now. I basically makes your existing IDE controller compatible with newer hard drives.
You can use an ordinary XTIDE ISA Card with IDE or CF interface. They will also replace the built in HDD support in your BIOS with the newer XTIDE BIOS. But it will use the ISA bus.
SOm Network cards also have a socket for BIOS - you can get an XTIDE Bios and put it on the Network card.
Have not tried this.
Check out my YouTube channel: Retro Erik https://www.youtube.com/channel/UCSUf7nCpwTgFbjGmcTYGZEQ
My collection: https://retro.hageseter.com
Reply 103 of 125, by Jinxter
konc wrote on 2021-09-15, 06:45:
Uhm, which IDE slot first of all?
Sorry i meant the ISA slot.
Reply 104 of 125, by dr.zeissler
ah, ok!
Reply 106 of 125, by Jo22
It wasn't exactly wrong, though.
Long ago, IDE HDDs were also called AT-Bus HDDs/Fixed Disks.
That's where ATAPI and ATA comes from (AT Attached).
IDE is a sub set of the PC/AT-Bus (now commonly being referred to as ISA).
Reply 107 of 125, by konc
Jo22 wrote on 2021-09-16, 12:51:
It wasn't exactly wrong, though. Long ago, IDE HDDs were also called AT-Bus HDDs/Fixed Disks. That's where ATAPI and ATA comes f […]
This is an XT though 😉
Reply 108 of 125, by Jo22
konc wrote on 2021-09-16, 14:38:
Oh. Right. My bad.😅
Then let's pretend it has an 8086/V30 CPU and a full 16-Bit data path. Then it's almost ISA. Sorta.. 😁👍
Some XT compatibles had pseudo-ISA with 16-Bit I/O, but merely 20-Bit address space.
Minus the upper IRQ lines and the second DMA controller.
For example, the Olivetti M24, S100 systems or Sergey's XT replica.
https://www.retrospace.net/infoseiten/readm.php?id=48
http://www.s100computers.com/My%20System%20Pa … CPU%20Board.htm
http://www.malinov.com/Home/sergeys-projects/sergey-s-xt
But yeah, you're right. A true ISA system uses an 80286 or higher CPU.
Reply 109 of 125, by Caluser2000
What is "true" ISA?
It is either PC-Bus or AT-Bus ISA. https://en.wikipedia.org/wiki/Industry_Standard_Architecture
Reply 110 of 125, by Jo22
Caluser2000 wrote on 2021-09-17, 00:40:
What is "true" ISA?
Neither?
After the 32-Bit EISA bus was defined by the Gang of Nine,
the specs for the previous 16/24-Bit AT bus were set in stone as a side effect.
That was necessary, because EISA had the old slot contacts as a legacy built-in.
The resulting "ISA" bus was similar to the AT bus, but not exactly the same.
ISA describes the timings for the bus, including a reference frequency of 8.33 MHz.
AT bus differed from this. The original PC AT Model 5170 ran at 6 MHz, originally, and had no upper limit yet (open ended, if you will).
(That's why some late 80s expansion boards were specced for up to 12MHz.)
According to the later ISA specs, that 6MHz PC AT must have run its bus out-of-spec, thus - if it was considered an implementation of ISA, which it wasn't.
To be fair, though, later ATs increased operation frequency to 8MHz, which still was a bit below 8.33 MHz.
However, that's not all, bus cycles might have been different, not sure.
You know, rising and falling edges. That low-level stuff.
To be honest, I'm too lazy to check right now.
Anyway, these are merely details.
It's comparable to AT-Bus vs IDE vs ATA0, I believe.
Most people will make no distinction between these.
To them, AT bus equals ISA equals and PC bus equals XT bus equals 8-Bit "ISA".
Which in most cases is close enough.
But there are subtle differences sometimes.
The original PC 5150 had one slot that was special, I vaguely remember.
Anyway, I just think that's interesting. 🙂
Reply 111 of 125, by Caluser2000
Jo22 wrote on 2021-09-17, 19:33:
Neither? […]
What is "true" ISA?
Neither?
Edit: Waiting for the first edit...😉
Reply 112 of 125, by Jo22
^Not after being quoted, that would be against the netiquette. 😀
Reply 113 of 125, by Caluser2000
Jo22 wrote on 2021-09-17, 19:53:
That is the whole idea.
Reply 114 of 125, by mkarcher
No, the special slot is not in the 5150, but in the 5160. It's "slot 8" which is driven by a different data path, and thus needed a "CARD SELECT" signal to activate that data path. I suspect the fan-out of the data drivers for the XT bus was insufficient for 8 cards, so IBM had to add a dedicated buffer for the eigthth slot. To avoid bus conflicts on reads, the CARD SELECT signal on slot 8 toggled whether the main XT-bus data buffer or the slot-8 data buffer was used to drive the data from the card to the processor bus. The 5150 had only 5 slots, so the issue wasn't present in that machine.
CARD SELECT was so obscure that the same pin got repurposed to 0WS on the AT bus.
Reply 115 of 125, by Caluser2000
mkarcher wrote on 2021-09-17, 21:38:
Well caught Dude.
Reply 116 of 125, by Jo22
Ah, I see. Thank you very, very much for taking your time for the detailed explanation! 😎👍
- I merely remembered it was somehow related to the original PC models (PC, XT).
It's things like this why I love this place so much, by the way.
In other forums, someone would likely just say "you're wrong" without giving a hint why that's the case.
Reply 117 of 125, by Jinxter
I have just found myself an EuroPC II. It has 768KB of RAM.
Does anybody know hos to use this 128KB of extra EMS? - The startup ram checker counts it as EMS.
    1.72 MiB
    EuroPC II RAM
Reply 118 of 125, by Jinxter
The BIOS in Euro PC say mentions JIM (v1) and Sara (V0) in IO 250h and 25Eh - What does this mean?
    1.33 MiB
    Bios 1.32 on Euro PC II
Reply 119 of 125, by theoryboy
Jinxter wrote on 2021-10-17, 18:19:
I think USE!UMBS and DOSMAX might suit you here. USE!UMBS to enable the high mem and dosmax to move command.com and others to high mem to free up conventional mem. Clearmem may be needed to clear memory blocks first.
