First post, by Orkay
- Member
I got an Intel EtherExpress 16 with a RPL ROM chip, so now I'm using that to experiment with the elusive Remoteboot service in Windows NT Server. RPL is an intriguing precursor to PXE that's not well documented in modern years, but I'm hoping to change that in time.
When a workstation is not yet configured to boot using the Remoteboot server, an adapter record is created in the Remoteboot Manager which can be converted into a workstation record; thus the administrator doesn't need to know the MAC address of the NIC.
Following the overwhelming documentation in the Windows NT Server Resource Kit, I copied an existing installation of MS-DOS 6.22 to the appropriate directory, ran rplenabl.exe on the client, and restarted to boot from the network card.
So far, I've got a rather barebones MS-DOS 6.22 profile set up. The virtual hard drive provided is read-only the way I have things set up now, but it almost seems like it's possible to make it writable in order to fine-tune profiles. Maybe not. 😒 Either way, I'll make occasional progress updates as I struggle to further understand this mysterious portion of retro networking. Reading Microsoft's seemingly mishmash documentation on this sure explains that Sun Microsystems commercial with the scuba diver's system failure!
