Reply 40 of 44, by gdjacobs
That must be your full module tree, then. Too small for it to be kernel source, too big for it to be just the driver (even with source).
Reply 41 of 44, by devius
The 18MB package? It's a rpm installable package for Fedora containing the actual built kernel. No source code is included.
Reply 43 of 44, by yawetaG
Although this is already marked as [SOLVED] I'd like to point out that FreeBSD still supports MFM drives (and loads of other older hardware) in its current releases: https://www.freebsd.org/doc/en_US.ISO8859-1/b … ity-drives.html
Generally they are less aggressive than Linux distributions in discontinuing support for old stuff.
Reply 44 of 44, by Jo22
Yea, Linux was always good in supporting hardware from the scrap yard! 😉
