First post, by Jade Falcon
Rank BANNED
BANNED
I been trying to build a all in one PC that I can use as a server, home system and retro pc and I'm having a hard time with the dos ends of things. Manly the sound card. I know that AC97, live and the audigy have dos support.
Just wondering how they work and if it will work with dos apps in 2k.
If I don't have to use dosbox I will not, but I'm thinking that I will have too.
As far as the dos games go, it will be only the late stuff like descent MechWarrior and duke3d and what not.
Reply 1 of 17, by TheAbandonwareGuy
Jade Falcon wrote:
I been trying to build a all in one PC that I can use as a server, home system and retro pc and I'm having a hard time with the […]
As far as the dos games go, it will be only the late stuff like descent and what not.
Based on my understanding only ISA soundcards will work with DOS apps as they can't detect PCI cards that lack the legacy IRQ resources unless you use a motherboard and card with SB-Link
https://www.youtube.com/channel/UCuFY6ZVlYOXA12tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
#Bernie2020 #FeelTheBern
Reply 2 of 17, by Jade Falcon
Rank BANNED
BANNED
then how do onboard AC97 chips work?
And couldn't you set you pci sound card to IRQ 5 or 7 in the bios? or dose it need dma/ports and what not to be right too?
Reply 3 of 17, by keenmaster486
PCI-based cards will work if they have special drivers. But if the card has an OPL3 chip, it's likely to work with minimal effort (maybe an initialization driver) since all it requires is I/O ports and no IRQ or DMA. It's digital sound that messes things up.
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 4 of 17, by Jorpho
There is no universal "AC97" DOS driver, if I'm not mistaken. If a motherboard supported AC97, it would only be usable in DOS if the motherboard manufacturer provided DOS drivers for the motherboard.
DOS apps never worked particularly well in Windows 2000. That's why VDMSound was created. And VDMSound is depriciated in favor of DOSBox.
(And Descent is playable in DX Rebirth, I might add.)
Reply 5 of 17, by Jade Falcon
Rank BANNED
BANNED
china Dos union had a universal AC97 driver for dos
I never had much troble with dos apps in 2k with a real isa sound card.
Reply 6 of 17, by clueless1
If it's anything like how the SB Live! works in Win98, then there are separate resources configured in Device Manager and EMM386 is required for sound to work in MS-DOS mode. But I don't know if that applies to a) the Audigy or b) Win2k. Maybe try downloading the Audigy Win2k drivers and see if there is a readme:
http://support.creative.com/downloads/downloa … DownloadId=9497
Reply 7 of 17, by keenmaster486
Where is it? I've been searching for that for years, and have never found it.
Reply 8 of 17, by Jade Falcon
Rank BANNED
BANNED
It was apart of there custom MS-DOS OS cd version if I recall.
I attached the diver folder in my copy of china Dos union drivers that I have. I don't think my copy has the AC97 drivers.
I think the via drivers are the ones you want.
I don't have any such card yet 🙁 . I was asking so I don't go and waste money. I have a nice card already.
Reply 10 of 17, by synrgy87
SB Live! and Audigy 1 have dos drivers, Audigy 2 and 2 zs can be made to work with the audigy 1 drivers but I've not tried that there's a patch floating around for it, I've only tried the Live! in dos and it seems to work well.
Some motherboard audio will be soundblaster compatible but depends on the chipset and manufacturer support and normally on older hardware. No experience using windows 2000 for dos based apps I tend to stick with DOS 7.10 or Windows 98se.
Reply 11 of 17, by Rhuwyn
If I understand Jade Falcon's question correctly he's wanting to know what they are like as in how the sound? Is this correct? I'd be interested in this as well as I've not tried to use one in DOS.
Reply 12 of 17, by Jade Falcon
Rank BANNED
BANNED
Not really, but it would be nice to now. Like does it use what ever sound font that's loaded or emulates opl3?
I'm more so wandering how well it works.
Reply 13 of 17, by synrgy87
under windows it will use a soundfont of your choice if you set it in the settings(duke3d sounds cool with piano), under pure dos it'll operate like waveblaster / general midi and SB16 emulation
The cards are dirt cheap really so not losing much by getting one to try out
Reply 14 of 17, by Jade Falcon
Rank BANNED
BANNED
I like the idea of that.
Now to find away to load up big sound fonts in 2k like 1-2gb
Reply 15 of 17, by boxpressed
Using Live!, I haven't been able to load a soundfont in Windows and be able to use it for DOS game run from. Windows DOS box (e.g. Duke 3D). No matter which soundfont I load, the default soundfont is the ECW patch set.
With my AWE32 with 32MB, however, I can use nice 28MB soundfonts with DOS games run from a Windows DOS box.
Reply 16 of 17, by falloutboy
This only works with WDM-drivers, I heard, not with VXD.
Reply 17 of 17, by Jade Falcon
Rank BANNED
BANNED
Yeah I recall having driver problems with soundfonts with such cards
