Reply 20 of 21, by KT7AGuy
RogueTrip2012;
No, those will use up an adjacent slot. For a single-slot cooler that works well with the GF4 series, try this one:
http://www.ebay.com/itm/2-Pin-80mm-Fan-Cooler … g-/261039851297
That's the same thing as the Evercool EC-VC-RI, only cheaper. I use several of those coolers on various Ti4600 cards that I own and have never had a problem. The BFG Ti4600 I have actually came with one of those coolers installed and without any heatsinks on the RAM. I added heatsinks to the RAM with thermal adhesive later.
Reply 21 of 21, by swaaye
Rank Moderator
Moderator
RogueTrip2012 wrote:
Is this single slot replacement? Hard to tell from the pic. Thanks.
No it would need two slots. You shouldn't be using the PCI slot below your AGP slot anyway because it typically shares IRQ with the AGP slot. 😀
