First post, by melbar
- Member
I have several mainboards which needs to be recapped.
Two of them have between 7 to 13 bad capacitors and also minimum two where the inside stuff comes already out.
This MSI mainboard on the pictures, i have got it on ebay and i have not seen the one missing capacitor, next to the 3 caps between IDE ports and RAM slots. I assume that maybe there was a cap-explosion...
What are the best to clean the mainboard, before to start to solder a new cap at this place.
From width and height - point of view - (i've seen on pictures from this mainboard MSI K7T266 Pro2, MS-6380 v2.0), i'll need a cap with 1000uF and 6.3 Volt.
