First post, by CkRtech
Is there any possible way to get 16-bit DOS support from a YMF719 when WSS isn't available? I just threw this card in my machine to run it through the gauntlet of games, and I fell short on NBA Live 95.
Installer options are -
Sound Blaster
Sound Blaster Pro (Testing plays 8-bit 16 kHz)
Sound Blaster 16 (Testing played 16-bit 22 kHz before I pulled my SB16)
Gravis Ultrasound
All detection is done via the set blaster string (or set "ultrasnd" or whatever the Gravis one is).
Just wondering if I have any options here.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 1 of 3, by gerwin
If the games uses miles sound drivers: Rename SB16.DIG to SB16.OLD. Find SNDSYS.DIG from elsewhere and rename it SB16.DIG. Your milage may vary.
Reply 2 of 3, by James-F
Whats the point?
Just use WSS with Miles Drivers if the card supports it.
As far as I know, SB has completely different set of commands than WSS, the two are not interchangeable.
Reply 3 of 3, by CkRtech
It seems like that is the only option available. Unless they have an odd rename of the drivers, I think whatever sound logic EA used must have been incorporated into their exe.
James-F wrote:
Whats the point?
There is an extremely noticeable difference between the quality of sound of 8-bit 16 kHz and 16-bit 22 kHz. It is possible that some people wouldn't think much about it if only hearing the 8-bit option, but the 16-bit option is highly superior in quality. Being limited to 8-bit 16 kHz is a regrettable loss of sound quality.
