First post, by Womble
Hi Folks, I have an MT-32 inbound needing some TLC, aside from other ailments it is missing the main knob on the front so I am looking for replacement. Can anyone with an MT32 help me out with the measurements of an original. Am after the depth and width of it as Jaycar have a couple of options that look roughly the right style.
Thanks 😀
Reply 1 of 2, by Ozzuneoj
What version of the mt32 do you have? I know there are a couple different ones. I'm not sure if the volume knob (or any other part of the front panel) is different.
I believe mine is the older\first version. I don't have anything super accurate to measure with but mine is 20mm diameter (with a small raised line that wraps around the edge for an indicator) and 10 or 11 mm deep. The half-circle shaft that protrudes from the back sticks out past the edge of the knob about 4mm or so. The knob is all black plastic with no paint.
Also, if your mt32 is just like mine, you'll see that it has a notch on the end of the volume pot's shaft. There is a line of plastic inside the knob that fits into this.
Hopefully this is helpful!
EDIT: I think they're mostly identical on the outside but just in case, mine is the old one with no "phones" jack on the back. https://en.m.wikipedia.org/wiki/Roland_MT-32
