First post, by computergeek92
Those internal 3.5 SCSI zip drives have the SCSI port that looks like a slightly longer IDE port. My motherboard has an onboard SCSI port that looks like a smaller, skinnier parallel port. Would a cable adapter work with no trouble?
Also, are the internal SCSI Zip drives any less reliable than the internal IDE ones? I'm had no problems with the IDE versions over the years.
And what about using a SCSI to IDE converter board?
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
