Wow... where do I even start...
At first I run Crysis with Very High settings in 4k resolution and with AA on a 4GHz Pentium 4 Extreme Edition "Galatin" and GTX 780 Ti (+4GB of DDR2 RAM), then I did the same thing for FX-55 and FX-60 (both OC'ed of course 😉).
Then I turned to Intel old Dual Cores, and tested OC'ed Pentium XE 965 with 8GB of DDR3 RAM in "The Division", Doom 2016, and Overwatch.
After that went reasonably well, I tried similar thing on the first Intel Dual Core (Pentium XE 840), but let me tell ya - 4,2GHz ain't enough to play games from 2016 😀
Then I put Pentium XE to rest a bit, and did my "AGP thing" (E5700 @ 4GHz + LOT's of GPU's, and QX9770 + HD 3850 AGP setup), thread about the latter is here : LINK
Moving on from AGP to modern-ish things again (like Pentium XE 965 and Core 2 Extremes in 2016), I'm now testing OC'ed Athlon 64 FX-62 with GTX 780 Ti in few games (BF1, GTA V, Call of Duty IW, DOOM (2016), etc.). It's Hell (DO NOT do this).
At this point, I think I'm a lost cause (even Arkham Asylum probably won't help me at this point 😁) - 100% CRAZY.
PS. I recorded almost everything when I was testing something with GTX 780 Ti.
