First post, by jcarvalho
Hi guys, I have bought a QDI Superb1 mobo. chipset SIS 530. It is a very flexible mobo. can configure multi and fsb in bios :
Supports Intel Pentium®CPU from 133MHz to 200MHz and Pentium®with MMXTM CPU
from 166MHz to233MHz.
l Supports Cyrix 6x86TM CPU at 100MHz(120+), 133MHz(166+), 150MHz(200+) and
Cyrix MIITM CPU.
l Supports AMD K6TM CPU from 166MHz to 300MHz, AMD-K6TM-2 CPU from 233MHz
to 500MHz and AMD-K6TM-3 CPU from 300MHz to 500MHz.
l Supports IDT WinchipTM C6TM CPU at 200/225/266MHz.
l Supports 66/75/83/95/100MHz host bus speed.
l CPU core frequency = Bus speed x1.5, x2, x2.5, x3, x3.5, x4, x4.5, x5, x5.5.
l CPU core voltage adjustable from 1.3V to 3.5V through on-board switching
voltage regulator with VID(Voltage ID)
I flashed the latest BIOS 2.5 SLC
Can I drop in an K6 2 plus? will it burn or just behave like an normal k6-2? Is it easy to modify the bios to work with k6plus? Any guidelines?
thanks!
