Reply 82 of 83, by novasilisko
appiah4 wrote:
Having an adlib clone PCB printed would probably not have been that much more expensive.. Of course, if that's the kind of project you want to undertake, by all means.
I dunno, I did a fair bit of looking around and every fab price I could find for something as large as the adlib board would have been far, far higher. But I also don't know terribly many places to look, so maybe I missed out on a chance to get one for 10 dollars or something. Though I would like to use these little boards (I've got 3) for other tinkerings as well, not just a breadboard adlib.
canthearu wrote:
i personally think Adlib is too primitive for a 386.
I mean... have you seen the rest of the build? 😜 I'm not exactly going for a strict adherence to era, this is very much an experimental beast... regardless though, I don't expect an adlib clone to be the last sound card I put into this thing.
Phoenix / The Disasterpiece
Processor: Am386DX-40 | Memory: 20 MB | Graphics: Trident TVGA9000B | Sound: TBD | Era: No
Reply 83 of 83, by SirNickity
It wouldn't be cheap at any of the PCB houses that I usually haunt. You're kind of limited to a minimum board size of 8-bit ISA slot length by (at least partial) ISA slot bracket height. That's why a lot of really cheap cards started coming out with a diagonal cut -- so they could put two back-to-back on the PCB panel and cut them in half, ending up with 1/2 or 2/3 the net area per card.
Be glad you're not making VLB cards. 😉
Small run PCBs are getting cheaper, but still kinda brutal with larger boards. And I do wish turnaround was a little faster. Still... beats messing around with home etching, IMO. Ugh. What a PITA.
Good luck with the Ad Lib clone. I see it as a rite of passage for any PC hardware hacker. It's the "blinking LED" of DIY ISA. 😀 (That or a POST card -- you get to pick.)
