The XL-7 TURBO 8088 XT build
Reply 20 of 26, by Predator99
Vynix wrote on 2020-03-27, 21:29:
Yes should work, though you may run into some problems with the BIOS not handling well the 1.44M FDC 😀
The IDE port won't work, obviously, but that doesn't really matter.
XT-IDE supports IDE with a 16-bit controller card in a XT. Works perfectly.
"- 16-bit ISA IDE in 8-bit mode Allows to use 16-bit IDE controllers on XT systems. This will require drive that supports 8-bit transfers (CF card and Microdrives all support 8-bit mode)."
Reply 21 of 26, by computerguy08
Predator99 wrote on 2020-03-28, 08:27:
Isn't the IDE header connected on the 16 bit bus (the shorter finger), which is disconnected in a 8 bit slot ?
Looking for a motherboard? You can find it in Ultimate Hardware 2019: http://www.win3x.org/uh19/motherboard/search
Join our UH19 Discord server here: https://discord.gg/HWWH7hsk2p
Reply 25 of 26, by Predator99
computerguy08 wrote on 2020-03-28, 08:57:
Yes, indeed. But with the XT-IDE-Bios only 8 bits are used. No need to get a 8-bit controller for a XT.
