feipoa wrote:What is ps2maset /r:3 for? I should use it with what baud rate and firmware?
v1.1 firmware at 19200 baud is fine for sleep, but I'm hoping to get the Logitech drivers working in Win95 and WinNT.
I plan to flash firmeware 1.0 -2400 this evening after all the kids are asleep. Now that it is spring break, the kids don't seem to get tired in the evening.
You can use that with 19200baud on the standard 1.1 firmware
Ps2maset.exe options:
/ G - Provides information about the current settings
/ P: n - COM-Port, possible values: [1-4]
if the parameter is missing, the COM port is automatically detected.
/ B: n - baud rate, possible values: [1200 or 19200]
/ C: n - sets the scaling possible values: [0-1]
0 = 1 to 1 scaling or 1 = 2 to 1 scaling
/ R: n - sets the resolution possible values: [0-3]
0 = 1 count / mm, 1 = 2 count / mm, 2 = 4 count / mm, 3 = 8 count / mm
/ S: n - sets the sample rate, possible values: [10-320]
usual values: 10, 20, 40, 60, 80, 100, 200
/ M: n - sets the mouse type possible values: [0-3]
0 = automatic selection
1 = Microsoft mouse
2 = Logitech Mouse
3 = Microsoft Wheel Mouse
