First post, by Dimitri
didn't tested yet.
bracket is the issue, drilled keystone 9202, STL for 3D is the only way for now. Next time maybe external wire to PCI bracket extension + 9202 bracket
has DIY IC kits with 9202 bracket.
Reply 5 of 20, by Dimitri
DIY kits board+8019AS+bracket available. No shop yet - in process. Paypal is the way to get it.
On the way ISA8 OPL3 boards, in development ISA8 IDE/FDD/LPT/2COM board based on W83787IF chip. All the chips available.
Reply 8 of 20, by matze79
Would you also offer the PCBs with hardgold finish ?
Reply 9 of 20, by root42
Seconded. Price for those is marginally higher. But much better for corrosion, I guess, and it looks nicer.
YouTube and Bonus
Reply 13 of 20, by konc
It would help if you could write where are you shipping from, how much it costs, if it's only a DIY kit or pre-assembled, say a few words about the software (eg. packet driver to use), how to configure the card... This kind of stuff I'm sure everyone considering buying one would like to know.
Reply 14 of 20, by Dimitri
shipping from Russia, Moscow to EU is usually $6, available clear boards, full DIY kits, brackets or fully assembled boards. All points is negotiable. The board is fully NE2000 compatible by the chip RTL8019AS + configurable ROM (optional).
Reply 17 of 20, by Dimitri
Limited edition: gold plated board 150th Birth Anniversary of V.I.Lenin, Soviet leader, available 35 pcs.
$8 for the red board with ENIG, $5 for red HASL.
