Reply 20 of 22, by luckybob
- l33t
Using a memory manager is actually VERY authentic.
One is even included in dos 6.22 its called memmaker
i'm personally getting a 486/66 optimized right now, and thanks to QEMM 8 I have 633K availible.
scsi, pnp network, pnp sound, cd all above 640k. 😀
edit, included are ym config and autoexec
config.sys
DEVICE=c:\qemm\dosdata.sysDEVICE=C:\QEMM\QEMM386.SYS RAM R:3device=c:\qemm\dos-up.sys @c:\qemm\dos-up.datDEVICE=C:\QEMM\LOADHI.SYS /R:3 /SIZE=11520 C:\QEMM\QDPMI.SYS SWAPFILE=DPMI.SWP SWAPSIZE=1024DEVICE=C:\DRIVERS\CT2940\CTCM.EXEREM DEVICE=C:\DOS\SETVER.EXEDOS=HIGH,UMBDEVICE=C:\QEMM\LOADHI.SYS /R:3 /SIZE=16416 C:\DRIVERS\SCSI\ASPI4DOS.SYS /DDEVICE=C:\QEMM\LOADHI.SYS /R:1 /SIZE=29904 C:\DRIVERS\SCSI\ASPICD.SYS /D:MSCD001FILES=30LASTDRIVE=ZDEVICE=C:\QEMM\LOADHI.SYS /R:4 /RES=3872 /SQT=FE00-FEFF /SIZE=4848 C:\WINDOWS\IFSHLP.SYSSTACKS=9,256SHELL=C:\QEMM\LOADHI.COM /R:3 /RES=3776 /SQF C:\COMMAND.COM /E:1024 /P
Autoexec.bat
@ECHO OFFPROMPT $p$gREM ***IMPORTANT*** NETWORK MUST BE INITIALIZED BEFORE SOUNDREM SET UNIVERSAL PARAMATERSSET TEMP=C:\DOSPATH C:\QEMM;C:\WINDOWS;C:\DOS;C:\DRIVERS;C:\DRIVERS\NETWORK;C:\DRIVERS\MOUSE;C:\DRIVERS\SCSI;C:\DRIVERS\CT2940;C:\DRIVERS\CDROM;C:\DRIVERS\NETWORK\MTCPREM MOUSEC:\QEMM\LOADHI /R:1 /LO CTMOUSEREM CDROM INIT -USE ONLY ONE-REM C:\WINDOWS\MSCDEX.EXE /S /D:MSCD001SHSUCDX /D:MSCD001REM NETWORK SETUPSET MTCPCFG=C:\DRIVERS\NETWORK\MTCP\NETWORK.CFGC:\QEMM\LOADHI /R:1 C:\PACKET\KTC2000P.COMC:\DRIVERS\NETWORK\MTCP\DHCPC:\WINDOWS\NET STARTREM SOUND INITSET SOUND=C:\DRIVERS\CT2940SET BLASTER=A220 I5 D1 H5 P330 T6SET MIDI=SYNTH:1 MAP:ESET CTCM=C:\DRIVERS\CT2940C:\DRIVERS\CT2940\DIAGNOSE /S /W=C:\WINDOWSC:\DRIVERS\CT2940\MIXERSET /P /QC:\DRIVERS\CT2940\CTCU.EXE /S /W=C:\WINDOWSREM RANDOM SHIT BELOWREM C:\DOS\SMARTDRV.EXE /X
