First post, by varrol
I have faulty ATMEL AT49F002NT-120PC - 120ns
Can I replace it with 90ns or even faster chip, or should I stick to 120ns?
Basically I want to buy WINBOND W29C020C-90B - 90ns - pinout looks the same with the difference in PIN1 - on ATMEL it is RESET and not connected on WINBOND
I only found information that it should not be slower.
AOpen AX6B+ | P3 1G | 1GB ECC REG | FX5200 | CT4500
AOpen AX59pro | K6-2 450M | 256MB | Rage 128
Asus CUBX-E | P3 1G | 512MB | GF4 TI4200 | YMF719E-S
Asus P3B-F | P3 933M | 384MB | Radeon 9200 | CT4520
Asus P5A | P55C 200M | 256MB | Riva TNT | CT3600
Reply 1 of 6, by Tiido
Faster speed is not a problem but what will be is the size, the chip you want to buy is 256KB while original is 512KB.
The reset pin is not going to cause problems when a part lacks it.
Reply 2 of 6, by varrol
Both are 2Mbit 256K x 8 according to documentation - which matches mobo spec: https://soggi.org/motherboards/asus/P2B-D.htm
Or maybe I got something wrong?
Reply 3 of 6, by Tiido
Sorry, I somehow read 49F004 instead of 002. That's my bad, there shouldn't be any problems trying to use the Atmel chip. There's a chance that you cannot program it with UNIFLASH or some other BIOS update utility and have to use an external programmer. Locate the datasheets and compare programming command sequences, if they're same then there won't be problems.
Reply 4 of 6, by varrol
Thank you, I'll order the chip then. I have a programmer, so no problem getting the new chip ready.
Reply 5 of 6, by varrol
Took a while - chip WINBOND W29C020C arrived - I flashed it and motherboard is working fine.
Reply 6 of 6, by Tiido
Very nice ~
