First post, by RiP
I try to get my ST02 to work but it reports: "SCSI Host Adaptor Failure"
The floppy port works fine though 😕
Reply 1 of 2, by Warlord
make sure the scsi cable is terminated. Check the drive ID jumpers and that its not sharing same ID with the controller, floppy or other device on the cable.
Try connecting just the drive to the controller with no floppy attached as well.
Reply 2 of 2, by RiP
Thank you, just terminated the HDD and ST02 detected it 😎
