First post, by AlessandroB
Today, checking my cpu collection, I found Pentium MMX in ceramic version. What is the difference between the ceramic and the plastic version? Do they have the same core and production process? L1 Cache? The only information I found is that the 233Mhz model is exclusive to the plastic version while at 166 and 200 there are both. Could it be for the greater dissipative surface to prefer the ceramic version ???
Reply 1 of 12, by The Serpent Rider
Plastic Pentium MMX has integrated heatspreader.
Reply 2 of 12, by derSammler
The ceramic version gets hotter, that's why it is enclosed in ceramic. The plastic version was optimized in production and produces less heat. Technically, they are identical in specs.
Reply 3 of 12, by Anonymous Coward
I think the first intel x86 CPU to use the plastic version was the P200 sans MMX. It got too hot for the ceramic packaging. When Intel started making the MMX chips, they used split rail voltages with reduced core voltage, which in turn reduced heat dissipation allowing the P166MMX and P200MMX to go back to the older ceramic package...perhaps until they used up whatever supply they had lying around.
Reply 4 of 12, by alvaro84
There's both ceramic and PPGA version of quite a few P5 models: classic 166/200, MMX 166/200 (desktop models). The insides are the same, I presume. The metal heat spreader should be better at transferring the core's heat to the cooler. Btw I have both kinds of 166-sans-MMX and both are stable at 200MHz.
AFAIK, the MMX-233 doesn't have a ceramic version, though, while the old classics below 166MHz are always ceramic.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 5 of 12, by AlessandroB
I asked this because I have a card with the 233mmx with the heatsink glued on and produce a very annoying noise. Unfortunately I can't install another CPU in plastic because the socket is not ZIFF and therefore it does not have hooks to block the heat sinks. I have to choose the heatsinks that hook directly to the CPU, and from what I know exist only for ceramic CPUs. That's why I wanted to use the Pentium MMX ceramic instead of the plastic version. Even if the ceramic version I own is only 200mhz I don't think it's too slower than the 233mhz plastic version. I forgot to tell that my board is a ss7 and bus can run at 100mhz, i can run my cpu at 100x2=200mhz. I think is really fast that the regular 233mmx (that can run at 100x2.5)...
Reply 6 of 12, by alvaro84
AlessandroB wrote:
...the regular 233mmx (that can run at 100x2.5)...
With some luck even the 200 can do the same. (Though the ceramic ones are usually from earlier batches so you have worse chances than with newer plastic ones).
Reply 7 of 12, by H3nrik V!
According to my own homemade Excel sheet, there is no ceramic 200 Classic. Was I wrong when making it?
Reply 8 of 12, by The Serpent Rider
Most likely not. Ceramic P200 were relabeled P166: https://www.cpu-galaxy.at/Article/fakes.htm
Reply 9 of 12, by H3nrik V!
Very interesting 😀
Reply 10 of 12, by AlessandroB
As i remember 200 classic is ceramic, then, when the 166mmx plastic come out, intel start to mix plastic and ceramic ,but 200 ceramic was made for sure.
Reply 11 of 12, by Anonymous Coward
Try to find one that isn't fake. I gave it my best shot but came up empty handed.
Reply 12 of 12, by alvaro84
I thought there was a very normal ceramic 80502200. So it was a fake...?
WANT 🤣
