First post, by treeman
this is a 486 vlb motherboard with no cache, it is a dca tech (direct cache access) if it makes any difference.
I don't remember if this board ever booted but it is not posting now and I noticed a hardware mod on what I think is one of the buffers or hex inverter near the cpu. I am very curious what it is supposed to do, and if I reverse it maybye it will boot?
The chip in question is a QUAD 2-INPUT AND GATE FAST SCHOTTKY TTL
so from my poor understanding it is a gate chip that lets data through 1 way but not back the other?
anyway here is 2 pictures, one unmodified and second where I circled the 2 jumper cables that have been attached to the chip, the original pin removed and rerouted to a resistors
Reply 1 of 7, by Tiido
This is a factory fix and reverting it will most probably cause nothing to work at all. It probably exists to correct some timing issue or maybe an outright routing mistake.
