Pentium II Upgrade Problems
Reply 20 of 29, by moawkwrd
flakes wrote:
Hi
You havent by mistake got one of the first P3 450MHz chips? if so they are a bit different and the bios may be upset. I had this issue when going from a P2 400 to P3 550. Board had issues like this until i found a BIOS update. (HP oem version of an ASUS board). After the BIOS it took an 800MHz on a slotkit.
Nope, definitely P2 450. BIOS recognises it correctly with the 4.5x jumper setting.
Xeon E3-1241v3 - 16GB DDR3 - Vega 56 - W10
PII 450MHz - 256MB SDRAM - Voodoo 3 3000 PCI - W98SE
Reply 21 of 29, by moawkwrd
Errius wrote:
moawkwrd wrote:
I don't have a fan to install though. You can see in the pics above that the heatsink isn't designed for a fan to be attached and there seem to be an awful lot of slot 1 Pentium 2s and 3s with those style heatsinks without fans, I can't imagine they all need fans somehow attaching to work. A quick search on here suggests plenty of people use them without fans. It just seems faulty, temperature related or not.
Some OEM systems have the CPUs inside a fan duct that pulls air across the heatsink and out the back of the case. Corporate/server machines often did this. A lot of the fanless CPUs you see on eBay were intended for these systems, and will run too hot if put in a regular case without additional cooling.
As said earlier it does have a 120mm directly above it as the PSU is relatively new. I used to have a Gateway with a P3 500MHz with a similar plastic shroud and only a heatsink on the CPU with an 80mm fan of the PSU for airflow and never had any temperature problems - it's heatsink was considerably smaller than this has also.
Reply 22 of 29, by moawkwrd
meljor wrote:
Try and disable l2 in bios. It will be much slower but if it is stable like that it's probably the l2 cache that's bad.
That cpu needs a bit of cooling though...
Will give it a go if I can find the setting, thanks. Still waiting for the seller to respond to the return request.
Reply 25 of 29, by The Serpent Rider
However, I've swapped it over today and it's causing all sorts of errors - memory problems, graphics distortions, system hangs, CMOS errors, etc.
Try to clean the contacts. Few Pentium II/III in my collection required cleaning to just work.
Reply 26 of 29, by moawkwrd
Did this today, and also attached a fan to the heatsink, still no luck. Oh well - I got my money back from the seller. Will look out for another cheap one to try.
Reply 27 of 29, by moawkwrd
tegrady wrote:
Have you checked for bulging capacitors on the motherboard?
Not a problem - motherboard is great with the Pentium II 350.
Reply 28 of 29, by moawkwrd
So I got hold of another Pentium II 450 - works fine first time after changing the jumpers!
One question though - it looks to have a third party heatsink/fan with an additional 2 pin connector - does anyone know what it's for?
Reply 29 of 29, by jaZz_KCS
Probably a second redundant 2-pin connector for a situation where you only would have a 2-pin connector available on the motherboard. Sometimes they are so tightly packed that using a 3-pin cable on a 2-pin connector is just not possible, space-wise. The sense pin is not needed per se on these as the temperature is monitored by a sensor below the CPU and the fan speed is slightly adjusted by the voltage.
