First post, by TOOL
https://3894a8e173f5f8870a41-c88208a08312eda3 … 26412492837.JPG
I have the blue one.
Can't properly close cd rom and zip drive. Everything is installed as it should, all the screw holes are aligned...
Any tips?
When i take out mounting bay with cd rom and zip, then blue plastic mask sits properly.
Reply 1 of 5, by Vynix
Are you using the original Apple CD drive? Could be that the drive you're trying to install is too long.
(Slight nitpick: It's not blue but rather "Graphite Grey", the only blue Power Mac was the original blue and white Power Macintosh G3)
Reply 3 of 5, by yawetaG
On some Macs the CD-drive lacks the bezel normally found on CD-drives, so if yours has a bezel and the front panel won't fit due to that it might be that the drive is not an original one.
Reply 5 of 5, by Mister Xiado
If it's an issue, I would drill and tap new drive mounting screwholes, so that the drive could be mounted further back in order to accommodate the case door.
