First post, by Windows9566
The voltage regulator to the right of my MMX 200 CPU gets way too hot after running for 15 minutes on my TC430HX. any way to make it run cooler?
Reply 1 of 23, by BushLin
Point a fan at it.
Screw period correct, I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 4 of 23, by Windows9566
gdjacobs wrote:
Linears will run hotter with split rail CPUs. Is the regulator heatsinked?
yes, many intel socket 7 ATX boards have huge black heatsinks, Advanced/ML, AG430HX (Sony OEM), TE430VX (Gateway/Dell OEM), TC430HX, AN430TX, LT430TX)
and thats why it was cooler when i used a Pentium 100 on it. MMX CPUs make the linear regulator get hotter.
Reply 6 of 23, by gdjacobs
Actually, you need to check the spec sheet of the regulator and mosfets to see what the max operating temperature is.
Reply 8 of 23, by bestemor
I have an Intel AN430TX which has the same huge and scorchingly hot metal lump of a cooling block for the mosfet as in the picture. I have tested holding/pressing down a 40mm fan on top of it, and that really helps a LOT!.
Now, there just the matter of how to 'permanently' attach and secure the fan to the block... 😀
Reply 11 of 23, by Anders-
ninkeo wrote:
Put a bigger heatsink on it? 🤣
A fan is a good option if you have one that fits in that space, just depends on if you want the noise of another fan in the case.
The cpu fan should provide enough airflow.
Reply 12 of 23, by The Serpent Rider
You can't. Heatsink is soldered to the motherboard.
Reply 14 of 23, by derSammler
I have the same problem with my MMX 200 build as well. The heatsink on the voltage regulator get so hot that you can only touch it for 2 or 3 seconds. However, human fingers are not a good indicator for temperature. If you can touch something for some seconds, it's probably not hotter than 70-80°C, which is still fine and should not cause any issues, apart from getting the heat out of the case.
http://retro-net.de/blog.html
Reply 16 of 23, by The Serpent Rider
If you can touch something for some seconds, it's probably not hotter that 70-80°C
Around 65 more likely. At 80 reflexes will kick in.
Reply 18 of 23, by derSammler
That's different to every person. With enough callus, you may be able to touch something that's 90°C for some seconds. Other people crying "hot" even at 50°C already.
Reply 19 of 23, by The Serpent Rider
Nothing that a soldering iron can't solve...
But you also need a new bigger heatsink which will fit.
