First post, by Edwin1996
Hi guys ive got a really annoying problem with unreal, about every 5 minutes the game freezes and the computer becomes unresponsive to anything but a reset. I've tried both my original copy of the game as well as unreal gold but this happens in both. If it helps my pc specs are
Voodoo 5500
Asus cusl2-c
piii 1.4ghz
512mb ram
sound blaster audigy (sb0090)
Windows 98se
Any help would be appreciated!
Reply 1 of 16, by athlon-power
Edwin1996 wrote:
Hi guys ive got a really annoying problem with unreal, about every 5 minutes the game freezes and the computer becomes unrespons […]
Voodoo 5500
Asus cusl2-c
piii 1.4ghz
512mb ram
Windows 98se
You might be able to run memtest86, as some of the RAM may have decided to give up. 512MB may be a tad too much for 98SE, but that's probably more personal opinion than anything else. Do other games work?
Where am I?
Reply 4 of 16, by dr.zeissler
I remember some Boards that draw to less power over agp but that was a BX (be2000?) with a voodoo3.
In that case I got random freezes and lockps while watching the unreal timedemo-sequence.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 9 of 16, by lost77
Since the problem seems to be consistent it could be a heat issue.
Try to run some stress software for the CPU like Prime95, Everest stability test etc.
The Tualatin doesn't generate much heat but it could be that the heatsink has poor contact.
You can also try to underclock the Voodoo 5 to maybe 130Mhz or less and see if you can play longer.
Reply 10 of 16, by Edwin1996
Both fans are working on the 5500, but it could be having a heat issue i guess. I have the computer in my beige box from the late 90s/early 2000s and the air flow is not great, but there are 2 case fans. Ill try the stress software as well as underclocking
Reply 11 of 16, by Edwin1996
Ive run prime95 and it was fine. I also run the Unreal benchmark for around 30 mins and it didnt crash but then when i entered the game it crashed after around 5 mins again 🙁 I turned the PC off and the voodoo and cpu were warm to the touch but not hot. This is really frustrating
Reply 15 of 16, by hasnopants
Doesnt unreal have a 'safe mode' or something equivalent? You could try running in that and see if it crashes? I tend to think this is a software issue though, curious if patching the game clears it up. Could be some compatibility with one of your drivers for your sound, video or something like that.
Current Systems:
DIP40|8088|640K|HERCULESGB102|PCSPKR
S7|P233MMX|128M|S3ViRGEDX/DM3D|SB16
S370|P600MMX|1G|SIS630/DM3DIIX2|SBLIVE!5.1
S775|P43.4|2G|6800GS|SBAUDIGY
Reply 16 of 16, by nali
unreal.exe -firstrun
But it's often more efficient to delete System/Unreal.ini.
Early versions of Unreal often crash in Glide. Patches must be applied, but not all !
If I remember, 224 is correct.
227 works usually great, but sometimes I had problem to have Win98 run it.
