First post, by hasnopants
- Member
Hey all,
Wanted to see if anyone else has a original 5160 and has dealt with 3rd party multi IO cards getting their ports too close to the back indention of the case. Its that indention that goes around the whole expansion IO area... Picture below:
I have a multi IO card and can't connect a serial mouse or the gameport joystick to it because the nub (screw in things) of the cable hit the lip of that case. Curious if there are 'screwless/nubless' db9 / gameport extensions...or how tough it would be to modify an extension cable.
Just wanted to see if anyone with one of these has dealt with this problem.
Thanks!
Current Systems:
DIP40|8088|640K|HERCULESGB102|PCSPKR
S7|P233MMX|128M|S3ViRGEDX/DM3D|SB16
S370|P600MMX|1G|SIS630/DM3DIIX2|SBLIVE!5.1
S775|P43.4|2G|6800GS|SBAUDIGY
