First post, by GiSWiG
I've been doing some research and found references to a program called TweakIt for tweaking Voodoo cards. Any download links I have found for it are long gone. The company is long gone. The only thing I can find are pictures of it. Does anyone have a copy of this software or a link to it?
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
Reply 1 of 5, by manbearpig
http://ftp.mpoli.fi/pub/hardware/DISPLAY/OTHER/
Premio 212B motherboard (MSI MS-6112)
Intel PentiumII 333MHz Slot 1 66MHz bus
384MB ECC 66MHz
SIIG ATA133 controller --> Seagate Barracuda 80GB
SIIG Gigabit Ethernet (RTL8169) / USB 2.0 / IEEE1394 controller
ESS 1869 soundcard on board wavetable synth
Reply 2 of 5, by GiSWiG
manbearpig wrote:
THANKS! Proof that Google can't find everything!
Reply 3 of 5, by manbearpig
Actually, I found that with a quick "let me google that for you" face:
https://www.google.com/search?source=hp&ei=nu … Q4dUDCAc&uact=5
384MB ECC 66MHz
Reply 4 of 5, by GiSWiG
I was searching with some combo of this, plus or minus a word
https://www.google.com/search?ei=ef1dXdjyJ43m … Q4dUDCAo&uact=5
But yeah, I semi-deserve the 'let me google that for you'
Thanks again
Reply 5 of 5, by manbearpig
No problem. Happens to the best of us.
Although I realized I put 3dlabs instead of 3dfx. I guess brain farts can be helpful sometimes.
384MB ECC 66MHz
