HWiNFO support of vintage hardware
Reply 540 of 554, by red-ray
HWiNFO32 locked up my system twice in the same place 🙁
file.php?id=123277
Reply 541 of 554, by Mumak
red-ray wrote on 2021-11-08, 23:39:
HWiNFO32 locked up my system twice in the same place :( […]
file.php?id=123277
Thanks, I think I found the bug.
Reply 542 of 554, by red-ray
Good and fingers crossed you have. I ran HWiNFO in the hope of checking we all reported the same Intel i740 clocks. Looking from Re: Need help to improve the support of 486/586/686 class CPUs in CPU-Z both AIDA64 + SIV report a memory clock of 100 MHz, but running HWiNFO32 on WMe it reported 66MHz, it was also much to big for the 640 x 480 display.
I also looked at https://vintage3d.org/dbn.php#sthash.VE9XlzHm.7wJJHkXn.dpbs and it has the i740 memory clock as 100 MHz, what do you think it should be?
file.php?id=123327
    13.33 KiB
Reply 543 of 554, by mastergamma12
I tried Hwinfo64 with a Quadro GP100, As with Ray's SIV software, Hwinfo doesn't know what the GP100 HDA controller is
file.php?mode=view&id=123421
    DARK-CRUSADER.zip
    20.27 KiB
    3 downloads
    424.25 KiB
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Reply 544 of 554, by Mumak
mastergamma12 wrote on 2021-11-10, 22:22:
I tried Hwinfo64 with a Quadro GP100, As with Ray's SIV software, Hwinfo doesn't know what the GP100 HDA controller is […]
Thanks. I have just recently added this device, so it will be fixed in the next build.
Reply 545 of 554, by mastergamma12
Sweet 😁
Reply 546 of 554, by feipoa
v7.14 portable crashes on loading - enumerating devices. Hangs up on USB detection. I have the motherboard's onboard Intel USB 1.x port enabled, as well as a USB 2.0 PCI expansion card installed with NEC 720101 chip.
Windows 2000 SP4
Intel PR440FX dual socket 8 motherboard with two PIIOD -333 installed
debug file attached.
Reply 547 of 554, by Mumak
feipoa wrote on 2021-11-19, 09:50:
v7.14 portable crashes on loading - enumerating devices. Hangs up on USB detection. I have the motherboard's onboard Intel USB […]
Windows 2000 SP4
It crashes during enumeration of the NEC USB controller. Is this a hang when HWiNFO stops responding and can (or cannot) be killed?
Reply 548 of 554, by feipoa
It leads to this pretty blue screen.
FYI, the BSOD occurs with AIDA64Extreme600 as well, but only if I click on the USB item from within the program. if I don't click on the USB device, I can use AIDA as usual. The information contained in the blue screens produced by hwinfo and aida are identical.
168.31 KiB
Reply 550 of 554, by feipoa
I can still access files on a USB flash drive using the NEC device. Is there a way to tell hwinfo not to probe USB?
Reply 551 of 554, by Mumak
feipoa wrote on 2021-11-19, 11:32:
Basic functionality probably works but the driver doesn't seem to properly handle additional query functions, it should in no way cause a BSOD when an application queries it.
Currently there's no option to disable USB scan, but it's not performed in Summary-only or Sensor-only mode.
I will add a dedicated option to disable USB scan in the next build.
Reply 552 of 554, by feipoa
OK, thanks.
Everest Home Edition doesn't have any issue with the NEC USB card, but I'm not sure if Everest is querying the same functions.
Reply 553 of 554, by Mumak
feipoa wrote on 2021-11-19, 12:18:
OK, thanks.
I don't think it does.
Next build of HWiNFO will allow you to skip USB enumeration if you insert "UsbEnum=0" into the INI file. This option won't be exposed via GUI yet.
