Reply 540 of 677, by red-ray
- Oldbie
HWiNFO32 locked up my system twice in the same place 🙁
red-ray wrote on 2021-11-08, 23:39:HWiNFO32 locked up my system twice in the same place :( […]
Thanks, I think I found the bug.
Good and fingers crossed you have. I ran HWiNFO in the hope of checking we all reported the same Intel i740 clocks. Looking from Re: Need help to improve the support of 486/586/686 class CPUs in CPU-Z both AIDA64 + SIV report a memory clock of 100 MHz, but running HWiNFO32 on WMe it reported 66MHz, it was also much to big for the 640 x 480 display.
I also looked at https://vintage3d.org/dbn.php#sthash.VE9XlzHm.7wJJHkXn.dpbs and it has the i740 memory clock as 100 MHz, what do you think it should be?
I tried Hwinfo64 with a Quadro GP100, As with Ray's SIV software, Hwinfo doesn't know what the GP100 HDA controller is
mastergamma12 wrote on 2021-11-10, 22:22:I tried Hwinfo64 with a Quadro GP100, As with Ray's SIV software, Hwinfo doesn't know what the GP100 HDA controller is […]
Thanks. I have just recently added this device, so it will be fixed in the next build.
v7.14 portable crashes on loading - enumerating devices. Hangs up on USB detection. I have the motherboard's onboard Intel USB 1.x port enabled, as well as a USB 2.0 PCI expansion card installed with NEC 720101 chip.
Windows 2000 SP4
Intel PR440FX dual socket 8 motherboard with two PIIOD -333 installed
debug file attached.
feipoa wrote on 2021-11-19, 09:50:v7.14 portable crashes on loading - enumerating devices. Hangs up on USB detection. I have the motherboard's onboard Intel USB […]
Windows 2000 SP4
Intel PR440FX dual socket 8 motherboard with two PIIOD -333 installeddebug file attached.
It crashes during enumeration of the NEC USB controller. Is this a hang when HWiNFO stops responding and can (or cannot) be killed?
It leads to this pretty blue screen.
FYI, the BSOD occurs with AIDA64Extreme600 as well, but only if I click on the USB item from within the program. if I don't click on the USB device, I can use AIDA as usual. The information contained in the blue screens produced by hwinfo and aida are identical.
I think this is some problem in the USB Host Controller driver as both HWiNFO and AIDA64 use standard Windows USB stack calls to enumerate USB device.
I can still access files on a USB flash drive using the NEC device. Is there a way to tell hwinfo not to probe USB?
feipoa wrote on 2021-11-19, 11:32:I can still access files on a USB flash drive using the NEC device. Is there a way to tell hwinfo not to probe USB?
Basic functionality probably works but the driver doesn't seem to properly handle additional query functions, it should in no way cause a BSOD when an application queries it.
Currently there's no option to disable USB scan, but it's not performed in Summary-only or Sensor-only mode.
I will add a dedicated option to disable USB scan in the next build.
OK, thanks.
Everest Home Edition doesn't have any issue with the NEC USB card, but I'm not sure if Everest is querying the same functions.
feipoa wrote on 2021-11-19, 12:18:OK, thanks.
I don't think it does.
Next build of HWiNFO will allow you to skip USB enumeration if you insert "UsbEnum=0" into the INI file. This option won't be exposed via GUI yet.
HWiNFO16 for 8086-286 systems released: Introducing HWiNFO16 (for 8086/88/186/188/286)
I ran HWINFO 6.1.4 today on my 486 build and I may have discovered a bug.
I have a ISA SB 16 CT2910, non-PNP card.
The program hangs on Peripherals Information 'Checking - PnP sound cards'
The card is not configured, no blaster variable and there may be a IRQ conflict but I figured I'd share. no EMM just himem sys, dos 6.22 on 486DX2 16MB RAM.
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
RobDos wrote on 2021-12-01, 21:02:I ran HWINFO 6.1.4 today on my 486 build and I may have discovered a bug. I have a ISA SB 16 CT2910, non-PNP card. The program h […]
The program hangs on Peripherals Information 'Checking - PnP sound cards'The card is not configured, no blaster variable and there may be a IRQ conflict but I figured I'd share. no EMM just himem sys, dos 6.22 on 486DX2 16MB RAM.
This is most likely some general issue with PnP support, not the sound card. Is the BIOS PnP-capable? I've seen a few with a flawed PnP support causing issues.
Mumak wrote on 2021-12-01, 21:36:RobDos wrote on 2021-12-01, 21:02:I ran HWINFO 6.1.4 today on my 486 build and I may have discovered a bug. I have a ISA SB 16 CT2910, non-PNP card. The program h […]
Maybe, the board has no PNP as far as I can tell.
I did a debug and there was pnpwake 24x before i rebooted it, i'm wondering if I'm just inpatient.
I did try with the pnp bios function disabled. I'll let it run overnight. Maybe the poor system isn't hung, just slow.
HWiNFO should tell you if the BIOS supports PnP if you enter the BIOS info screen. If yes, it will also try to show PnP devices there. If not, it will attempt to detect PnP devices without BIOS support in the bus section. Would be interesting to see those screens and what happens there.
So it's certainly a bug. I left it run overnight and I now have a 8MB debug file from it.
It's filled with
PnP Wake 0 -> 255 then repeats,
It's stuck in some sort of loop.
I wonder if because no PnP Wake has a result it repeats?
