Reply 40 of 44, by The Serpent Rider
The K6 FPU is a lot slower than the P6 FPU in the Pentium Pro, Pentium II, and Pentium III
With 3dfx card, AMD K6-2 400Mhz/66Mhz is more or less on par with Pentium Pro 200Mhz 256Kb or Pentium II 200Mhz.
Reply 41 of 44, by athlon-power
I recently acquired an ATI Rage 128 VR 8MB and a K6-2 266MHz- maybe I could use those, and overclock the K6-2, or I could give it the 8MB ATI card and overclock the Pentium 200MMX?
With that ATI card, I may start getting somewhere.
Where am I?
Reply 42 of 44, by rmay635703
I had a Cyrix MII-300 in 1999, but I rarely had over $500 in a computer all in, sometimes less than $100
Funny thing was I always had a big 60gb HD of some sort 1999 onward.
My first k6-2 was in 2000 and clocked in at 450,
Not long after I got my parents a Duron 700 SIS 740 based machine (for the business)
I upgraded the k6-2 to a Slot A Athon 750 in 2002, the motherboard was very flakey but fully reliable once you learned its startup procedure.
Fun times
Reply 43 of 44, by The Serpent Rider
Unfortunately, early ATi cards are bad option for AMD K6-2, because they don't support 3DNow! instruction set. You should look for any 3dfx, Nvdia TNT+ or S3 Savage 4. In that priority order.
As I've mentioned before, 8mb Riva TNT would be quite authentic for a budget 1999 build. While a bit of a stretch in terms of availability for early 1999, S3 Savage4 8mb also would be also decent option.
Reply 44 of 44, by athlon-power
I got the ATi card for free; I have no money at the moment, so a ~US$30 (the cheapest OG TNT I can find) card isn't going to be possible. I always want to be as authentic as possible, but there are always times where I will have to compromise because of a lack of funds.
If the R128 doesn't support 3DNow!, I will have to overclock the P55C and make do with that. I hope it will at least work better than the buggy, broken (at least on any non-Intel chipset, figures) Intel 740 card.
Where am I?
