First post, by SirNickity
I just got a Teac FD-235F 100-U drive -- 3.5" 720KB that won't read or write disks. It seeks fine on bootup, and will respond to commands, but (for e.g.) trying to format a disk just results in a track 0 error.
I think it may have been used for something non-PC (Amiga?) because the D0 jumper was set when I got it. I'm having some trouble finding a jumper reference for this particular model, so I don't know what exactly the pin positions do WRT Ready and Disk-Change signals on what pins. Here's what it's set to now:
o o MS
o o IR
| o | o RY
| o | o DC
| o o | D1
o o D0
I found one picture online where the vertical jumper was set to short the RY row instead, with nothing on DC. This just caused DOS to report that the drive wasn't ready, so I assume the above is correct...? But if that's the case, I think the drive might be toast. 🙁
Just wanted a second opinion before I assume a less-than-common model is beyond salvaging. I have, of course, cleaned the heads. Have not yet tried cleaning and re-lubing the worm gear, but it all looks relatively clean and the drive sounds nice and quiet in operation.
