First post, by keenmaster486
- l33t
Title says it all.
I want to have both 5 1/4 and 3 1/2 inch floppy drives in this computer.
I added the 5 1/4 drive, and made it drive #1, with the 3 1/2 inch drive as the "B:" drive (on the cable).
But in the BIOS there is only a setting for the first drive! So I set it to 1.2 MB 5 1/4 inch drive. And lo and behold, it works perfectly.
BUT the system does not even recognize the B: drive at all.
So does this motherboard not even support dual floppy drives? Was that even a thing? I always figured it either supported two drives or none at all.
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
