486dx4-100 setup questions
Reply 20 of 21, by CoffeeOne
derSammler wrote on 2020-01-13, 20:48:
But why they needed 2 jumpers for 1 bit of information?
That's no "information". These jumpers directly change the voltage routes coming from the voltage regulator(s) and going to the CPU.
No, I don't think so. The current needed by the 486 cpu won't be routed via a jumper 😁
Reply 21 of 21, by mpe
The current obviously doesn't flow via jumpers.
These jumpers are a part of an adjustable voltage regulator circuit where you need to create a reference voltage for the regulator. That's typically the role of these two jumpers + some resistors. Often there are more levels supported or the chosen solution might have a good reason for having multiple jumpers.
I've seen many different ways of configuring the voltage. Two jumpers is a very common and IMHO by far the most common on a 486.
Blog|NexGen 586|S4
