First post, by appiah4
I bought a small bundle from a seller. There was an unimportant ISA VGA in the lot that I knew was repairably damaged (loose resistor needed resoldering). Apparently the seller decided to test the whole bunch out of goodwill. To my surprise they all work (screenshots and videos were sent to confirm), and a mystery CPU I got on a board turned out to be a Cx5x86-100 (Yay me?). But he went the extra mile and fixed the ISA VGA card as well.
With superglue.
127 KiB
130.61 KiB
He swears it works (and sent video to confirm) but I would of course like to remove the superglue and solder it back down properly.
How do I remove the cyanoacrylate without damaging the card?
Reply 1 of 16, by pentiumspeed
Best way is hot air heat around 300C-350C will melt and vaporize that type, use flux as well. I had one happen to me at our cellphone repair and had to "melt that glue out" of the LCD screen's spring clip (mounted to the frame's but removed trying to scrape glue out by a tech with no success till I tried heat to help out,) for iphone. Don't ask me why, it was like that when came in for repair, some guy who tried to fix themselves botched it up.
Cheers,
Great Northern aka Canada.
Reply 2 of 16, by Tiido
I haven't had any good results heating superglue, plus the fumes that come off are incredibly harsh and you definitely need a face mask to prevent inhalation and any getting in your eyes. I have just mechanically displaced the glue when it gets in the way. It won't bond to the PCB and metal so it should come off pretty easily.
Reply 3 of 16, by beastlike
Acetone is typically what I go for to remove superglue residue from my items (and my fingers). I've never had it damage a surface, but I don't know what acetone, or the mixture of dissolved superglue and acetone would do to the surrounding components.
Reply 4 of 16, by maxtherabbit
beastlike wrote on 2020-01-20, 23:42:
Acetone is a great and powerful solvent. So much so, I'd be afraid it would dissolve the solder resist
Reply 5 of 16, by Tiido
Acetone has no effect on almost any electronic part (only outer sleeves of e-caps and various other soft plastics) or PCBs, the soldermask is completely immune to it.
Reply 7 of 16, by krcroft
Acetone (aka nail polish remover) can do a number on many plastics!
I had one of those thin, very hard dental night-guard/grind retainers, which I left on the counter, and I accidentally knocked over my wife's nail polish remover. Although I wiped up the general spill, I didn't bother doing a detailed job (thinking it would evaporate on its own).
Well, my assumption about evaporation didn't matter because within hours the stuff had liquified the bottom portion of my night guards (finally a permanent reason not to wear them) 😀
Reply 8 of 16, by Horun
appiah4 wrote on 2020-01-21, 05:23:
Acetone it is then.. How about IPA though? Or lemon cologne?
Do not think IPA will cut it. Lemon cologne ? hahaa might make it smell fruity but doubt it will clean it.
Just don't get acetone on the IC's, should not hurt the coated epoxy board or any traces.
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor. https://archive.org/details/@horun
Reply 9 of 16, by kaputnik
To effectively dissolve cyanoacrylate, you'd need some chlorinated hydrocarbon, and those are hard to come by nowadays. In most civilized countries, you need some kind of license to buy them, they're not very healthy. There are special cyanoacrylate solvents too, but got no idea how PCB laminate, solder mask, and electronic components react to them. Acetone can have some limited ability to dissolve hardened cyanoacrylate, but is far from effective.
I'd simply use a combination of heat to weaken the bond and mechanical removal in your case. Just take your time, and all should be fine.
IPA and other relatively polar solvents won't work at all.
Are you absolutely sure it's cyanoacrylate btw? It would really be an odd choice for that application. Epoxy would be far more likely in my opinion.
Reply 10 of 16, by appiah4
It is indeed cyanoacrylate. The seller is an ignorant (no offense) scrapper, he just used what was conveniently available.
Although ideally I would like to, I dont have to remove all the CA On the PCB (it is not polar and therefore not conductive right?); hopefully there isnt much on the underside so I can just mechanically clear it and apply some solder. The card works as is. Just CA isnt a great thing to fix cold solder joints 😁
Reply 12 of 16, by appiah4
The Serpent Rider wrote on 2020-01-21, 09:33:
I would leave it like that. The card not worth it.
Ok. To you maybe. I think its a fun restoration. The card is useful in 286 and 8-bit PCs for me.
Reply 13 of 16, by kaputnik
appiah4 wrote on 2020-01-21, 08:50:
Well, conductivity has nothing with polarity in that respect to do, rather with chemical bond types and how readily electrons can flow between nuclei, but no, hardened CA is not conductive 😀
Sounds like a sensible approach to the problem. Probably what I'd done too if removing all of it was too much of a hassle.
Reply 16 of 16, by yawetaG
krcroft wrote on 2020-01-21, 05:57:
Yes. It either dissolves them outright or damages them.
And it can cross the barrier that is called skin if left soaking long enough, so if you get it on your fingers, wash hands immediately with lots of water.
