First post, by red_avatar
Yeah I know I'm pushing my look but here's the situation - you can see the specs in my signature of the PC I've installed it in:
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
This PC previously ran XP on this SSD but since I already had a more recent XP machine (i5-2500k - 3GB - SB Audigy 2) which has really good compatibility with early 2000's games, I needed a more powerful Windows 98 machine to handle games such as Baldur's Gate and so on - my IBM PC350 P233MMX is good for games up till 1997 but that leaves a gap of 4 years and some of those games didn't run well on Windows XP or had compatibility issues so ... Windows 98SE it was.
I wanted a relatively clean install:
- Windows 98 SE itself
- drivers for sound card, graphics card and the Philscomputerlab USB drivers for USB sticks
- WinAMP (for old time sake)
- VLC
- Filezilla (to move files between my main rig and this one)
- Paintshop Pro 7 (also for old time sake and it's a great program to open and browse pictures in)
- Daemon Tools
Now, twice I've had the installation break completely due to a single crash. The second time now, it removed ALL files from the Windows folder leaving just a single big file. I can't even do a scandisk since all files are gone, even the command line ones. The BIOS certainly supports the full drive size, I've done a full scandisk without any errors but it doesn't seem right that Windows 98 is this unstable and that it causes the drive to get corrupted this easily. My other Windows 98SE PC is rock solid in comparison.
Does anyone have any idea what the cause might be? Would a bad RAM stick be possibly responsible for this?
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 1 of 14, by canthearu
Windows 98 doesn't have an IDE driver that will handle disks more than 128 binary gigabytes.
Keep your partition smaller than that, within the boundary of the first 128 binary gigabytes, as that may be the source of your corruption.
Reply 2 of 14, by red_avatar
canthearu wrote on 2020-01-22, 21:49:
They're two partitions of 125GB so I took that into account - I forgot to mention that. Both C & D are the same size.
Also: my P233MMX has a 128GB SSD formatted with a 30GB partition (the BIOS won't see any drive bigger than that) so I can conclude that Windows 98 itself is unlikely to be blamed. I have the exact same software on there except for VLC and WinAMP (except for the drivers of course).
Retro game fanatic.
Reply 3 of 14, by canthearu
red_avatar wrote on 2020-01-22, 21:50:
Using the second partition will probably cause corrupt the first partition then in WIndows 98, since windows 98 can only safely access the first 128gb of your drive, placing any data beyond the first 128gb of your SSD will cause the writes to wrap around and hit the wrong parts of the disk.
Try with a single 120gb partition, leave the rest un-partitioned.
Reply 4 of 14, by debs3759
Have you tried using something like Puran File Recovery to recover the files? It doesn't solve the problem of the files getting deleted, but might be useful. I've never used it to recover system files though, so can't guarantee it will help.
Reply 5 of 14, by derSammler
The limit has nothing to do with partition size. If the drive is larger than 128 GB, Windows will write to wrong LBAs, even if you install it onto a 1 GB partition. You simply can't use a drive that large. This also applies to external media like USB sticks.
Apparently there were third-party drivers that could get around this, but I've never seen or tested them, nor would I trust them to always work correctly (if at all). Like the >512 MB RAM issue, this is a fundamental design flaw in 9x and is best avoided by using period-correct hardware.
Reply 6 of 14, by red_avatar
derSammler wrote on 2020-01-23, 06:48:
So I should get a 64GB or 120GB SSD then to play safe? I figured it was something related to how Windows reads/writes to the drive but didn't know if it was a BIOS problem or a Windows problem.
Retro game fanatic.
Reply 9 of 14, by Jo22
There's another thing that comes to mind.. alignment. I know, this matter is getting annoying..
Anyway.. Unlike CF/SD cards, true SSD likely aren't made with FAT32 in mind, but rather NTFS or EXTx.
With a wrong alignment, a flash drive's performance and life time *may* drop noticeable.
And problem is, aligning FAT32 is difficult to impossible. 🙁
I'm no expert here, so please have a lookt at one of my earlier posts, which has a lot of links added to it.
Re: SSD in a Vintage Computer
Edit: More precisely, aligning FAT32 clusters is the problem.
FAT32 itself can be aligned using GParted quite easily, of course, but this doesn't solve the issue.
Edit: Another thing that I forgot to mention. The CacheMap mechanism.
Win98 can run executables that are aligned to 4K boundaries straight from the cache.
Anyway, this isn't related to the SSD/alingnment matter really. Just mention it since it's special to Win98/Me.
https://www.techrepublic.com/article/speed-up … -with-winalign/
https://msfn.org/board/topic/151798-does-fat3 … age/2/#comments
Reply 10 of 14, by canthearu
You don't need a smaller drive!!!
You simply need to make sure that you don't use any part of the disk after the first 128 binary gigabytes. If you don't have any partitions after the first 128 binary gb on the drive, the operating system won't try to access anything further than that and you won't get corruption.
If you have a 500gb drive, and you only allocate the first 100gb on it to partitions, you are fine, no corruption.
If you have a 500gb drive, and you try to allocate 200gb of partitions on it, you will get corruption.
A guy called Lowe did make an IDE driver that fixed this issue, but I do not know if it works properly, and I do not know if it works in Pure DOS mode (DOS 7.0)
Now, knowing this limitation, you may switch to a smaller drive so you are not wasting space on the bigger drive, but it isn't a requirement to get things working.
Edit: You can use a low level disk tool to adjust the Host Protected Area on your drive, make it appear to be a smaller drive than it was originally, however, some BIOSes stupidly use this themselves to do BIOS backups and will overwrite your HPA setting.
Reply 11 of 14, by red_avatar
Warlord wrote on 2020-01-23, 08:01:
you can patch the OS so there is not a limitation. https://archive.org/details/hcdp_20191002 Also suggest the sata patch if you […]
Also suggest the sata patch if you use sata ssd
https://archive.org/details/PTCHSATA
Thanks for the info. The motherboard doesn't have SATA - I just used a small device to convert PATA to SATA. Would it still need the SATA patch then?
The first link is interesting. As someone else already mentioned, it may still be better to just limit myself to 120GB to avoid running into problems under DOS. 120GB should be plenty for Windows 98.
Retro game fanatic.
Reply 12 of 14, by DosFreak
It's simpler to use a smaller partition but here is the rlowe patch from the main website if you want to use it
https://rloewelectronics.com/distribute/PATCH137/
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 13 of 14, by red_avatar
Quick update: sticking to one partition of 128GB fixed it indeed. Everything works great now - having a PC that age that is extremely quiet (CPU has a modern ultra quiet Arctic fan that I can't even hear when it's spinning) is really sweet. The "real" hardware back then was noisy as hell with rattling cases, CD/DVD drives that sound like a jet engine (I use Daemon Tools for everything and store all images on the hard drive).
One question though: if I were to add a second 128GB SSD drive, I assume it would work fine then?
Retro game fanatic.
