First post, by Graham1982
Hello everyone:
First post here, looks like a brilliant forum.
Okay, I have been building PCs since I was 15, about 20 years ago, this was back in the Socket 7, IDE days. After this time I have been building/sourcing/repairing machines as a side gig.
As part of the aforementioned side gig, someone brought me a Cmpaq Deskpro PIII which he was still using to run CAD.
Right the HD is busted in this and I happen to have a couple of IDEs lying around.
Please take this post from a very basic level and don't assume I have done anything, as I probably haven't - I used to know my way around these machines like the back of my hand but all of the knowledge has subsequently been forgotten.
Right, I have put two IDEs into this system (both old, both could be broken, but I doubt both are) separately i.e. both at separate times, they both don't work.
As soon as I try to boot from Windows 98 CD and then boot with HD support, I get given an A:\ but C:\ doesn't exist. When putting the old, broken HD in, this is recognisable and I can list the directory.
I have messed with jumper settings on each drive and still n joy.
Both "new" drives are visible in the bios.
Needless to say I don't have copies of Dos lying around as I am not geared up for this kind of tech any more.
Do I need to use some sort of disk management program to mount the drive/set cylinders or something?
Thanks
Graham
Reply 4 of 12, by derSammler
Graham1982 wrote on 2020-01-30, 20:27:
That's completely normal. You need to run FDISK and create and format a partition first before you can access C: (and D: etc. if you create more than one partition).
FDISK is actually on the Win98 CD. If you boot with CD-ROM support, you should be able to completely set up the hard disk from the Win98 CD.
Reply 5 of 12, by Graham1982
Hi everyone:
I did the FDISK and that has moved the situation on a bit, thank you.
I used this to partition the drive, deleting the presumably XP partition and putting on a DOS partition. The machine said reboot and then format.
Herein lies the problem, the boot cd doesn't seem to have the format command, I tried format c:\ from memory but that doesn't work, presumably because the command doesn't exist.
Also if this helps, when I tried to Dir the c:\ prompt it said something about unrecognisable file system (or something)
Thanks
Graham
Reply 7 of 12, by pentiumspeed
fdisk, format and sys are on first disk of dos 6.22 3 disk set. 5.0x Dos don't know but you can obtain the boot disk from a website and create one using external usb floppy drive.
Cheers,
Great Northern aka Canada.
Reply 8 of 12, by konc
Graham1982 wrote on 2020-01-30, 21:51:
Help us a bit here. What's the error you're getting? Bad command or file name? You shouldn't, if I remember correctly format is in the same place where fdisk is so you should be able to run it.
Another thing that comes to mind without having much feedback is the syntax: it's "format c:" without the "\".
In any case since you're able to boot from the win98 cdrom everything you need is either on the virtual drive or the cd it self. After you format the drive you can run setup.
Reply 10 of 12, by LewisRaz
derSammler wrote on 2020-01-31, 08:24:
format.com should be in the win98 folder on the CD.
I remember that catching me out in the past being too hasty to set up PCs.
Installed a fresh windows 98 on a machine today and remembered that 😀
cd win98
format c:
Job done 😁
My retro pc youtube channel
Reply 11 of 12, by Disruptor
Graham1982 wrote on 2020-01-30, 21:58:
Hi derSammler: […]
Hi derSammler:
Just re-read your post regarding fdisk, is there a format command in fdisk?
Thanks
Graham
Hi,
FDISK is on the Win98 Floppy (or, when booting from CD on virtual drive A)
FORMAT is in the Win98 directory of the CD. (boot disks MSCDEX should report the drive letter for the CD drive)
Reply 12 of 12, by Graham1982
Dear all:
Many thanks for answering my queries - I was totally unaware this forum existed until a friend pointed me in its direction.
The machine is now working and is ready to be collected by the customer tomorrow.
I think that special thanks are needed because unlike on several Facebook enthusiast groups (I won't name names, not the point), you answered the question I asked and did so politely, without over engineering the situation.
All too often on the aforementioned groups if you pose a question you will get a silly response. For example, old guy doesn't want to upgrade his machine can he still use XP?
No, if I were him I would use Debian/Linux.
Clearly not a sensible option for an older person, 🤣.
Anyway, sincere gratitude, I will be back if someone decides to, I dunno, run their company accounts on a Sinclair/Timex!
Thanks
Graham
