First post, by arncht
hi,
i know about 3 editions of the dx2-66:
* naked, as oem cpu
* overdrive as retail cpu (boxed)
* blue heat sink version? where they use it? what was the reason of this edition?
i did not find any info about it. originally i thought this cpu was the retail, but from the newspapers looks the overdrive was it.
Bought this retro hardware
Reply 1 of 16, by brostenen
I have seen tons of different coloured heatsinks on 486's. I had a gold/copper-coloured one on a 486-dx2-66 in an IBM at some point.
The glued on heatsinks, just came in whatever colour, the maker of a given machine chose to use. Basically it is just a standard CPU.
Reply 3 of 16, by AlessandroB
brostenen wrote on 2020-03-14, 11:49:
I think he intend CPU stock directly from intel, not modify one by the PC builder.
Reply 4 of 16, by brostenen
AlessandroB wrote on 2020-03-14, 13:21:
Ahhhh. I see. Well. In that case, I have no idea on what different colours Intel used for heatsinks that they sold preinstalled on their product's.
Reply 5 of 16, by arncht
these are the intel official heat sinks (the blue and the overdrive). the question: was the blue sink version an oem or a retail product?
Reply 6 of 16, by arncht
here they write... boxed
http://www.cpu-galerie.de/html/intel486-80486dx2.html
but how the box looked? the overdrive is obvious.
    217.22 KiB
Reply 8 of 16, by arncht
thx... with this type of blue sink? in this case it looks, the blue version is also an oem solution.
Reply 10 of 16, by arncht
derSammler wrote on 2020-03-15, 11:14:
No, that's the normal retail boxed release. OEM had no heatsink at all.
where is the box? i did not see any, just overdrive boxes.
Reply 13 of 16, by BitWrangler
I've seen them, but last one I saw in the wild was about 345 moons ago.
Reply 15 of 16, by waterbeesje
I've got one, it was found in a dead HP Vectra ISA only system.
It's a regular DX2-66, blue sink glued with all the Intel printings on it. To me it seems like an Intel product, not glued by hp.
Stuck at 10MHz...
Reply 16 of 16, by BitWrangler
Yah that's the time period I'd peg them for, first 2 or 3 years of DX2 existence, when they were high high end, and before VLB had much market penetration. Probably why they're not real common, volume would have been quite low compared to when the masses got DX2s.
