First post, by perhenden
My 486 motherboard has a non-removable 486 sx-25 chip, and an empty overdrive socket (socket 1).
The best choice would be to get hold of an overdrive CPU, and insert it into the empty, waiting socket.
To save money I would like to use a 486 DX2-66 CPU available to me for the upgrade. The motherboard supports this speed.
Can I put the 168-pin 486 dx2 in the 169-pin overdrive socket? Will it fit, will it work? (doesn't have it yet, cannot test).
Option 2: Is it risky to de-solder the sx-chip and insert the dx2 chip in its place?
EDIT: This is a Compaq Presario 425 mother board.
Reply 1 of 4, by Horun
What is the manufacture and model of your motherboard ? I had a soldered SX-16 with a OD socket that allowed a DX33 as well as an ODP, just had to change a few jumpers.
How would you insert the DX2 PGA where the SX-25 SMT is ? You would have to solder in another socket, which you already have one...so NO !
Reply 2 of 4, by mpe
It depends.
If you can't remove the original CPU, it needs to be disabled somehow. As designed by Intel this is normally done by UP# pin which is an input signal on standard processors and output on the overdrive (ODP models). Thus when inserting the Overdrive chip to the socket he original CPU sees the signal from the upgrade chip and disables itself.
But as mentioned above some motherboards have jumpers that can do it without assistance from the Overdrive chip. You can also modify the socket (or the CPU). All you need to do is to set UP# signal to low which might be easier than unsoldering the chip.
If you disable the original chip somehow then you can use any chip in the overdrive socket. It doesn't have to be overdrive model.
Blog|NexGen 586|S4
Reply 3 of 4, by perhenden
Horun wrote on 2020-04-12, 21:59:
mpe wrote on 2020-04-12, 22:34:
Nice! There are jumpers to disable the on-board CPU, for when using the overdrive socket.
Thanks, this makes me happy 😀
