Found the CFG and drivers for Maxtech NX32EISA nic while looking for other nic drivers. Two diff cfg's...header of !acc1200 :
"Configuration file name : !ACC1200.CFG 12/06/1991
; For EISA EtherNet Adapter hardware version R00, R01 (long card)
BOARD
ID = "ACC1200"
NAME = "32-bit EISA-bus Ethernet Adapter"
MFR = " "
CATEGORY = "NET"
SLOT = EISA
LENGTH = 195
READID = YES
BUSMASTER = 23
AMPERAGE = 1000
IOCHECK = INVALID
DISABLE = SUPPORTED
COMMENTS = " The 32-bit EISA-bus Ethernet Adapter is a 32 bit EISA
bus master adapter based on SONIC Ethernet controller."
HELP = "32-bit EISA-bus Ethernet Adapter\n
This configuration file allows selection of the following:\n
1. BOOT ROM disable/enable\n
2. Bus master preempt time\n
3. Interrupt channel\n
4. Burst or non-burst transfer\n
5. Physical media selection"
Zipped up the self-extracting .exe and a NS Sonic datasheet, 7-zip can open/read the .exe
Has cfg's, dos, os2, wfw, netware, etc drivers...
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor. https://archive.org/details/@horun
