First post, by SodaSuccubus
- Member
I thought i'd ask here first before i go around messing another 486 board up again 😜
Anyone mind helping me figure out how to OC a 586-133 ADW to 160? Im not a jumper wizard and i don't wanna risk breaking something by playing around.
Is it just as simple as changing the "cpu clock selector" jumpers to 40mhz or do i need to set the other jumpers to something diffrent entirely
I have it running fine at 133mhz right now, a bit slower then i see online in some others machines but the ram is as tight as its gonna get right now.
Chris 3D: 72.7 - 43.6 FPS
Superscape: 57.1. FPS
PlayerBench: 16.4
Doom: 2134 gametics in 2149 realtics - 34 FPS
Quake: 12.5 FPS
The board in question is a LS486. (The big motherboard revision, i guess this is the original?)
Thanks! 😀
