First post, by ultra_code
Hello VOGONS.
Recently, I got ahold of an Asus P5E Deluxe socket 775 motherboard to do some extreme overclocking of my QX9650 with it, and, as I usually do, I completely removed all of the heatsinks off of the board so I could give both the board and the heatsinks a good cleaning, and then reattach the heatsinks with new TIM (pads and paste). However, I was caught off guard by the fact that the X48 northbridge had an IHS on top of it.
That got me thinking: Did anyone ever try delidding this northbridge (does only this board have such an IHS, or do all X48 boards have them?), and did Intel use paste or solder underneath the IHS? I'm very curious as to whether it's possible to delid the northbridge and apply high-quality thermal paste or liquid metal to improve thermals in order to get better FSB clocks. Kinda dumb, but I could see that being a thing.
Thanks!
Builds
Reply 1 of 7, by The Serpent Rider
Hard to say, but knowing Intel, they probably never bothered to add indium on relatively cool chip.
Reply 2 of 7, by ultra_code
The Serpent Rider wrote on 2020-07-08, 22:52:
But guessing and knowing are two different things. There's got to be someone who knows the answer, or know who to talk to to get the answer.
Builds
Reply 4 of 7, by ultra_code
darry wrote on 2020-07-11, 20:10:
Rumour has it that the X48 is actually a binned and rebranded X38 . So the answer to your question is likely an X38 .
I heard that rumor before, but that doesn't necessarily answer my question.
Builds
Reply 5 of 7, by darry
the_ultra_code wrote on 2020-07-11, 21:29:
I know and I hope I did not offend. It answers the question in the literal sense, but does not provide the info you are searching for . My comment was meant more as a humorous interjection . I should have added an emoticon. 😀
Reply 6 of 7, by ultra_code
darry wrote on 2020-07-11, 21:46:
😒 Wasn't offended, just... DISAPPOINTED!
Now, if it were just a better-binned X38 chipset, I could understand the use of thermal paste without the IHS, but with an IHS, it doesn't make sense. That would make it harder to transfer heat away from the northbridge, because of the additional layers of transfer materials the heat would have to pass through. It would make the most sense if solder was used, but again, we don't know if that's the case.
Builds
Reply 7 of 7, by lordmogul
Anyway, I doubt northbridge cooling will limit the system before anything else does. I got a X5460 running in 456 FSB, and had a E8400 on 467 FSB running on a P35 board. Not even that, but at 473 FSB my Corsair DDR2-800 OEM sticks are at their limit, so I haven't tried further. Pretty sure you will be able to run something like 8x500 with DDR2-1200 before that northbride becomes an issue.
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
