First post, by GigAHerZ
- Oldbie
I have AMD PCnet ISA+ network card, which i wanted to get working on my 386.
While messing around, i found a configuration utility which was able to switch this from PnP mode to manual setup. I used default configs and all was good... until i rebooted.
Now whenever the NIC is in the computer, i get beep codes saying me there's a problem with video card. (AMI bios, 8 short beeps)
Obviously i've set the card to use something that conflicts with VGA.
I've tried multiple VGA cards and even tried without any VGA card, but whenever the NIC is in, i get the beeps without machine booting up.
What are the possibilities to somehow maybe reset the configs inside this NIC?
Thanks!
