First post, by adama
Hi Guys,
I'm trying to put together a "fast" win98 system, but I'm running in to some performance issues i don't remember from the olden days.
The system is an AMD Athlon XP 2000 on a KT400 board. IDE drive is a 120GB Deskstar with an 80-conductor cable. the KT400 has a ATA133. I'm using Hyperion 4.56.
I keep getting "freezes" when it's doing a lot of HDD IO. I originally thought it was network related, because the machine almost locks up when downloading files from an in-house web server, but it completely freezes when copying large files between hdd partitions.
Is this me not remembering how poor Win98SE was, or do I have a conflict or misconfiguration somewhere?
Thanks!
Reply 1 of 12, by BushLin
Make sure you have the blue end of the IDE cable plugged into the motherboard.
Listen for a high pitched clicking noise from your HDD, you may have a "deathstar" GXP60
Try another disk anyway if you have one.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 2 of 12, by Jorpho
adama wrote on 2020-11-11, 17:38:
Are you using Windows Explorer? Does the same thing happen when you use XCOPY on the command line, for instance?
It is well-known that Windows Explorer in 98SE with IE6 installed will hang during some file transfer operations.
Reply 3 of 12, by adama
Cables seem fine, drive doesn't seem broken, though I might swap to something else to see if it just goes away.
It sort of does seem to be just in Windows, though it's a bit harder to get an indication in DOS. Copying Win98SE files from CD seemed to be as fast as I'd expect.
Running ATTO i get ~5MB/s Write speeds and ~60MB/s read speeds. Trying to run Sandra's storage benchmark has taking quite some time... 😁
Reply 4 of 12, by BushLin
Have you installed the chipset drivers and enabled DMA in Device Manager?
60MB/s isn't indicative of a hardware issue and Windows 98 is plenty fast for working with files if the setup isn't garbage.
Reply 6 of 12, by cyclone3d
Did you use the unofficial Windows 98SE SP3 package? If so, those are some of the same exact things I was experiencing after installing it.
The Deathstar HDD is also highly suspect.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 7 of 12, by pentiumspeed
The unreliable deskstars was 60 GXP and 75 GXP. 120GB GXP not these and regard any hard drives as something to break, no matter what.
The one sound you should listen for when any hard drives begin to fail; is "tiak-tiak" which is two back and forth head seeks twice every time computer attempts to access, once you hear that, back up quick what you have not backed up.
Cheers,
Great Northern aka Canada.
Reply 8 of 12, by adama
The drive in question isn't one that was part of the Deathstar debacle, but it is a drive that was used in a 12 disk storage array for a great many years, so it has a lot of hours on it.
I've never seen quite this kind of behaviour by a drive before. It's a strange half-failure state.
Swapping to a 40gb seagate i had on my desk seems to have fixed the issue.
Reply 9 of 12, by pentiumspeed
Long hours on hard drives will wear out regardless. Do not do that by reusing them from long hours.
One time I bought 3 used hard drives one Hitachi, two seagates which were all 2TB range; all were enterprise and seller didn't state how heavily they were in use. All 3 showed performance issues and that "tik-tak" started to show.
Broke them down for analysis and two of them had FDB bearings worn out that disks wobbled too much.
Cheers,
Reply 10 of 12, by adama
Yeah, these disks got a lot of vibration too, since they were screwed into drive cages with no shock absorption. Pity, this was one of the only ones of those disks that actually still worked without clicking! 😀
Reply 11 of 12, by Jo22
cyclone3d wrote on 2020-11-11, 20:45:
I know. But ironically, it's the best performing and most stable HDD type my Power Mac G4 ever saw. 🤣
Reply 12 of 12, by digistorm
I am waiting for my Deathstar to die 🤣 it has had bad sectors for over 15 years by now and it still refuses to give up. So I figured I use it as my testbed for OS and driver experimentation. Formatting is agonizing because of the long “kggg kggg kggg” scraping sounds but it doesn’t seem to gain new bad sectors. So, I just go against all advice and keep using it 😅 (but I image it regularly).
