Reply 40 of 46, by Robhalfordfan
- Oldbie
maxtherabbit wrote on 2020-11-26, 16:34:I have that same LSI card, it does work to boot DOS without drivers. Your card's BIOS may be disabled.
Another possibility: the card may not install its own BIOS int 13 routines if you have the main system BIOS setup with an IDE hard disk. If you try to boot from a floppy with *only* a SCSI disk connected it should appear as drive C:
ok i did try that and don't think my mobo has it own bios int 13 and where in bios setting would it in to enable scsi bios etc, if i can
