First post, by amigopi
Hi! Sorry if this is the wrong forum for this, I'm new here.
To the point. I'm looking for BIOS updates for the Alienware m5750/m5790 laptop. I'm especially interested in the 2.06 version but the 1.19 and 2.07 would also be good. Dell doesn't seem to offer any BIOSes for these laptops anymore and all the links I've managed to find have been dead.
The purpose is to get my first ever laptop, a Fujitsu-Siemens Amilo Pi 1556, to accept more than 2 GB of RAM and I've come to understand that the Alienware BIOSes are the way to make that happen. 2.06 apparently allows 2.5 GB with nVidia cards (good for me, since I have a Geforce Go 7700 7600), while the other two would allow even 3+ GB but only work with ATI cards.
Thanks in advance!
Into the eyes of nature, into the arms of God, into the mouth of indifference, into the eyes of nature...
Reply 1 of 8, by Horun
I found 1.19 but nothing on any 2.0x version except old posts.
Attached it below but use at your own risk !
Be sure to read the included PDF on how to use the file.
Reply 2 of 8, by cyclone3d
The problem is that those old Alienware laptops are from before Dell purchased them and Alienware were really jerks about requiring you to have a login on their site to be able to download anything.
Here is the archive for the 5750/5790. Only the 1.19 BIOS was archived... or I am looking in the wrong place:
http://web.archive.org/web/*/http://aliendl.a … /Mobile/m5750/*
There was a 5790 1.20 BIOS. The file name was:
m5790_Bios_1.20N.zip
Attached it the Alienware BIOS file from here:
https://www.bios-mods.com/forum/Thread-REQUES … =87547#pid87547
Alienware_BIOS_support_4GB_RAM.zip
486.73 KiB
159 downloads
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 8, by Horun
That archive http://aliendl.alienware.com/Mobile/m5750/BIO … 0_Bios1.19W.zip is same I grabbed and attached.
From everything I looked thru the 2.0x versions were not for the 5750/5790 but for 5550 and a few others iirc (will check my search history but am fairly sure found nothing else)
Alienware was just as bad+worse on their desktops too but at least if an Asus or Asrock board you could look up the board but you have to force a flash or use an external programmer as they modded some parts so genuine Asus or Asrock bios will not flash using standard methods.
Reply 4 of 8, by PC Hoarder Patrol
If I'm reading this right
https://forums.laptopvideo2go.com/topic/22155 … and-video-card/
the 2.06 from the m5550 is being used on the m57xx / fs models for increased ram + nvidia support?
Here's v2.06 if you want to risk it.
m5550_BIOS_2.06w.zip
964.13 KiB
123 downloads
Reply 5 of 8, by cyclone3d
Here is some consolidated info about the M5750/M5790 and M5550 BIOS interchangeablility:
http://web.archive.org/web/20090329005937/htt … showtopic=14069
Altough Alienware doesn't provide BIOSes for everyone, there's a method to get them.
First, you should google to know which is the latest bios version. (Yes, this is a lil' research, but worth it)
Apply the following syntax:
http://aliendl.alienware.com/Mobile/[model]/BIOS/[Model]_Bios[version].zip
Working examples:
http://aliendl.alienware.com/Mobile/m5750/...0_Bios1.19W.zip
http://aliendl.alienware.com/Mobile/m5750/..._BIOS_1.15W.zip
http://aliendl.alienware.com/Mobile/m5550/..._BIOS_2.07w.zip
(notice: the m5790 1.19W is
And an off-topic remark: m5550 is based on Uniwill P53, m57x0 on P72, and the Uniwill P53/P72 generally shares the same bios code, so they're interchangeable. (A living example: I'm using the m5790 1.19W on my Amilo Pi 1536)
P53 based notebooks are (known by me so far):
FuSi Amilo Pi 1536/1556
Alienware Area-51 m5550
Vega P53
Rock Pegasus P660/665
P72 based:
FuSi Amilo Xi 1526/1554
Alienware Area-51 m5750/m5790
Important notice: Remove any BIOS passwords before upgrading and rebranding, or else you may get locked out from your own notebook.
YMF7x4 Guide
Reply 6 of 8, by amigopi
Horun wrote on 2020-12-10, 01:24:
Thank you! Downloaded & will strive to keep safe.
cyclone3d wrote on 2020-12-10, 04:08:
The problem is that those old Alienware laptops are from before Dell purchased them and Alienware were really jerks about requir […]
Thank you for the link and the BIOS, downloaded!
PC Hoarder Patrol wrote on 2020-12-10, 04:30:
If I'm reading this right […]
Thanks! Yes, that's the thread I originally got my information from. I must've gotten confused with the whole m5550/m5750/m5790 thing. It's not exactly the easiest to read thread in the history of the internet... Anyway, this is exactly the BIOS I was most after, awesome.
cyclone3d wrote on 2020-12-10, 05:07:
(snip)
Thanks, seems to also confirm that the 2.06 should work on my laptop.
I'm in awe of how fast you guys delivered and how much interest this gathered. I'm in your debt. I'll edit the thread title to also include the m5500 to help people also looking for the BIOSes to find their way here.
Sadly the original Geforce on my laptop has died and I'm waiting for a replacement, and I don't have the sticks for more than 2 GB of memory yet either, so I can't really test any of this at the moment... 😀 I'll be back to let you know how it turns out once I start receiving my parts in the mail.
Reply 7 of 8, by amigopi
amigopi wrote on 2020-12-10, 18:36:
Yeah, so I haven't been able to test any of the BIOSes yet. I got the replacement graphics card I'd been waiting for some days ago and just installed it. No luck, didn't fix my original issue: the screen goes black after about 1 minute of using the laptop, no matter if I'm in BIOS or Windows or wherever; I'll have to try it with an external display, and if that doesn't work, then I guess it might be the motherboard that's busted... Sigh. 😒
