Help for Motherboard id
Reply 21 of 27, by Carstenl
i have tried with a new bios chip, that was flashed with the bios image from a MSI-4134 board.
But still no bios codes on the PC analyzer card.....perhaps the board is dead ?
Reply 22 of 27, by Deksor
Maybe it's misconfigured ? But without any manuals, figuring out the comfig is going to be tough ...
Reply 23 of 27, by Carstenl
Yes, could be that.
But still no manual for the jumpers, so it is going to be tough...
I will put it on the shelf for now, maybe someone will be able to find the jumper settings at some time.
/Carsten
Reply 24 of 27, by weedeewee
haven't seen anyone else mention it yet so I'll add it here AV9107
https://www.datasheets360.com/pdf/1373490396022218128
Check if it is connected to any of the surrounding jumpers even the unpopulated ones and the unpopulated bridged ones.
I'm guessing JP26, by that lone jumper on there it's either configed at 40MHz or 50 MHz
Apparently this chip can set a clock from 2MHz up to 100MHz and you can verify if it works if you got an oscilloscope.
Do not ask Why !
Reply 26 of 27, by weedeewee
all you'd need would be a continuity function on a multimeter. no scope necessary.
Do not ask Why !
