First post, by greasemonkey90s
Came up on this board in a lot looks to be in good condition but is missing the bios chip. Anyone with this board can recommend me the correct chip type to attempt to flash. Best way to go about this hot swap, programmer or socketed nic.? I find this board to be interesting to keep just hard to find much on this rev versus the more common rev 2.2 . Thanks for the help.
Reply 1 of 3, by greasemonkey90s
Any more information on this board in general. Having a hard time finding any info on rev 2.3 . Wondering if they fixed rev 2.2 issues with 100fsb. Has a 5 ns onboard cache so should be enough.
Reply 2 of 3, by Horun
Can you post a picture of the board ? Being a minor revision (not same as going from 2.x to 3.x with some boards) doubt much changed between 2.2 and 2.3....
Reply 3 of 3, by greasemonkey90s
Horun wrote on 2021-03-01, 00:37:
I attached it. Basically just want to know if the bios from rev 2.2 will work hopefully.
