First post, by Almoststew1990
- Oldbie
I am trying to revive a Dell XPS 1530 laptop. It does not power on at all. I plug in the charger and the charger's LED does not light up. Does the LED light up even if the laptop is not turned on? I.e. this would indicate a dead charger. If the LED is not meant to light up when the laptop is off, this means the charger could be fine and the laptop itself has issues.
But I don't know which it is!
