First post, by SteveC
So I got this old Compaq Contura 3/25 off eBay recently - the seller said it worked but dim screen. I've been having fun with it this evening!
327 KiB
Powering it on and yes the screen is very dim - the backlight doesn't work, but hey I've been playing with an Amstrad PPC640 recently - who needs a backlight!? 😀
179.05 KiB
158.47 KiB
It has BIOS errors (CMOS battery flat) and doesn't boot and the hard drive sounds bad. Open it up and take out the old Conner drive to check the cyl/heads/sectors to configure the BIOS but yeah it's bad - makes a horrible noise when accessed. The BIOS incidentally is very nice, but the hard drive can only be a 'type' - no auto detect and no custom types allowed! I don't have any small 2.5" (bit tall!) hard drives - the smallest I have is an old 815MB one I removed from my Libretto as it has bad sectors. I used this drive anyway, and set it to drive type 64 - correct heads and sectors but about 1/5 the number of cylinders so only the first (I assume) 1/5 of the drive is used - it formats and seems to boot fine (the bad sectors are about 300MB into the drive).
Next the backlight - opened up the screen and tested the inverter board and it all seems fine. I found a blog post (http://www.toughdev.com/content/2011/09/compa … c-80386-laptop/) where they do some work on the same laptop and link to someone else who had a failed backlight and it was a leaking capacitor and a broken track underneath it. I test all this and it's fine and the inverter output was very live so it's the CCFD tube that's died. No idea if you can replace these but then I had a brainwave - can I use LEDs? I have various LED tapes laying around but none thin enough to fit in the groove the CCFL tube was in so off to eBay and I order some 5mm wide SUPERBRIGHT LED tape. I now realise I need 12v to power this tape - there seemed to be a bunch of voltages available on the inverter board but I'm not sure what to use yet. On Amazon I order a TINY step down/buck converter module and a tiny step up module in case I need to use a 5V line or something. Thinking about it I decided to play it safe and use the 18.5V line that seems to come straight from the input jack and step it down as the current draw will be lower than stepping up.
44.79 KiB
continues...
Reply 1 of 7, by SteveC
The stuff turns up and I start messing about with wiring the step down converter to a fuse on the 18.5v line on the inverter board and the 5mm tape (https://www.ebay.co.uk/itm/5mm-Slim-Thin-WHIT … 872.m2749.l2649) fits very well:
1.03 MiB
26.93 KiB
There's loads of room around the LCD panel to fit this little power supply module (https://smile.amazon.co.uk/gp/product/B07MY31 … 0?ie=UTF8&psc=1):
209.96 KiB
And so I put power into the laptop and the backlight comes on immediately - oh this power rail I'm using is permanently on. Oh well I'm never going to use this on battery anyway so it's fine being on whenever there's power applied.
Hit the power button and WOW it's amazing! I'm so pleased 😀
313.99 KiB
221.61 KiB
It's been running now for about an hour and it's only a little warm to the touch so I'm happy. I measured the current at 0.18amps so that's fine as the module can do up to 3A supposedly but in the restricted space I wouldn't want to push it.
Now to install Windows 3.1 on it 😀
Cheers,
Steve
Reply 3 of 7, by SteveC
DOS 6.22 and Win 3.1 all installed now 😀
    615.95 KiB
Reply 4 of 7, by Thermalwrong
That's a great idea retrofitting an LED strip for the backlight - it looks nice and bright 😀
One of my Clevo pentium laptops had a bad backlight, but I got lucky it was fixed by replacing a single capacitor. The screen is still pretty dim though, I might try doing a similar retrofit at some point.
Reply 5 of 7, by Hiddenevil
I’ve just bought a 4/25c with dead screen. Wonder if this is why it’s dead. Though I did buy it for its DC power board..
There's an old android saying which I believe is peculiarly appropriate here. In binary language it goes something like this: 001100111011000111100, which roughly translated means: "Don't stand around jabbering when you're in mortal danger!"
Reply 6 of 7, by SteveC
Hiddenevil wrote on 2021-10-09, 20:17:
If it is the back light then you should still be able to see the image on the screen just very faintly (see the first pics on my first post) - using a torch can help.
Reply 7 of 7, by Hiddenevil
I’m hoping it does work, if so I’ll certainly try your fix. Though i might try and tap power from somewhere other than the input jack. A very cool fix!
I wonder if I could steal the light tube off the b&w screen and use it on the colour panel.
