First post, by Eep386
Just today I got this board from a swap meet. I got very lucky I guess, mine seems to work (knock on wood!).
Discovered that PC CHIPS had disabled a good many options in the BIOS, probably to fake a better return rate on their product by locking various options to conservative settings. I re-enabled most performance-relevant options, and also ran rom.by's BIOS patcher on it to fix various issues (incorrect handling of Ultra DMA modes, >64GB LBA issue, etc). I also set Video BIOS Cacheable to Disabled by default so that random video cards don't go ballistic.
SDRAM Bank Interleave is among the options enabled, when set correctly this can give the memory performance a nice lil boost.
Based on a ca. 1997 BIOS, I forgot which revision exactly, but it should be superior to anything earlier than 1997 at least.
download/file.php?mode=view&id=106911
I'm still testing it out, use at your own risk. Play it safe, burn it to a second flash chip just in case. You'll need a 1Mbit / 128K DIP flash chip for it. For reference, the flash ROM used on my board was a rebadged Macronix MX28F1000.
    PC CHIPS M537 Edit.zip
    113.33 KiB
    43 downloads
Reply 2 of 2, by Eep386
Go ahead and add it to UH19 if you like. I've yet to see any issues, but then my board could simply be one of the 'good' ones.
