Socket 7 to SLOT 1 adapter?
First post, by C0deHunter
Hello all,
Is there such a thing available? I would like to have the flexibility to swap my PIII-800MHz SLOT with *possibly* a Socket7 CPU, that allows me to play some CPU Sensitive DOS games.
I believe there is an adapter for Celeron Socket 370, but I don't want that:
I need a Socket7 adapter, as I have plenty of loose original Pentium and MMX Socket7 waiting to be utilized.
My system specs are in my signature file.
Thanks!
PIII-800E | Abit BH-6 | Rage 128 Pro Video Card | 256MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 2X SanDisk (2004) 2GB CF as C:\ (Win98SE OS) and D:\ (DOS Games) | Windows 98SE (using PhilComputerLabs', *pure* DOS option)
Reply 2 of 37, by C0deHunter
OK, thanks, I feared as much.
Reply 3 of 37, by C0deHunter
C0deHunter wrote on 2021-04-14, 19:00:
What is the lowest speed SLOT 1 Pentium CPU that I can find, which is close to the original Socket7 speed?
Reply 4 of 37, by paradigital
I think you may be trying to solve a problem in a less efficient way.
As far as I was aware, the “best” solution for slowing down a relatively quick Slot 1 system would be using a VIA Nehemia or Ezra/Ezra-T Socket 370 CPU in a slocket adapter. This combined with turning caches on or off, and playing with SETMUL will allow you to have anywhere between ~66MHz and ~1.2GHz at your disposal.
Reply 5 of 37, by Doornkaat
Covington Celerons are pretty slow since they have no l2 cache. They perform at Pentium1 levels. I guess this is about Socket 7 speed.
But you could also just disable the l2 cache on a Pentium II for about the same effect.
Reply 6 of 37, by C0deHunter
I use SetMUL L1D, and L2D commands often, but I wanted a *permanent* hardware solution!
Reply 7 of 37, by C0deHunter
C0deHunter wrote on 2021-04-14, 19:12:
Would a SLOT 1 PII-233~266 be close enough to the speeds?
Would any of the following be suitable?
https://www.ebay.com/itm/Intel-80522PX266512- … g0AAOSwa8dZwuKx
https://www.ebay.com/itm/Intel-Pentium-II-805 … r8AAOSw1oJdI0W1
https://www.ebay.com/itm/Intel-Pentium-II-805 … D8AAOSwaWhZwth6
https://www.ebay.com/itm/Intel-SL2HE-Pentium- … ~wAAOSwJU5d1FsS
Reply 9 of 37, by zyga64
Slowest Slot 1 CPU is Pentium II 233 Klamath (or maybe cacheless Celeron 266MHz) ?
Besides that, some SLOT1 cpus are multiplier unlocked. Lowest possible multiplier is 2x (automatically disabling L2 cache) or 2.5x with L2 enabled.
I have for example PII 400 SL2S7 which can be clocked 133Mhz (2x66 without L2) and 166Mhz(2.5x66MHz with L2) up to 5x100MHz stable.
1) VLSI SCAMP /286@20 /4MB /TVGA9000C /CMI8330
2) i420EX /486DX33 /16MB /TGUI9440 /YMF718+GUS
3) i430HX /P233MMX /64MB /VirgeDX+3DFX /YMF701
4) i440BX /P II 400 /256MB /MX440SE /SBLive!+Vibra16s
5) i865G /E5800 /2GB /Ti4200 /YMF724
Reply 10 of 37, by dionb
zyga64 wrote on 2021-04-14, 19:19:
Depends on what you're throwing at it.
The Celeron 266 has the same core as the P2-333, just no L2 cache.
FPU-intensive stuff (Quake...) runs pretty well, only marginally slower than on a P2 at same clock,on par with a P2-233. On the other hand, ALU-intensive code tends to suffer badly. In MDK it is beaten by a P200MMX and only just scrapes ahead of a Winchip 2 233...
Yep. And you can always disable L2 cache on CPUs that have it. A P2-233 with L2 disabled is slower than the Celeron-266, not to mention one of the early Deschutes CPUs without multiplier lock.
Reply 11 of 37, by flupke11
As dionb and zyga64 said, the first PII's can be clocked at 2*66 or even 2*60 FSB on boards that still have FSB switches. The old PII's should be easier to find than the cacheless celerons.
Reply 12 of 37, by C0deHunter
Thanks! Which one of the eBay links do you recommend then?
I am about to order the one that you recommend as soon as possible!
Reply 13 of 37, by mothergoose729
paradigital wrote on 2021-04-14, 19:08:
Yep, I have a nehemiah processor. With enough creativity you can run it at any speed.
https://docs.google.com/spreadsheets/d/1usQPR … krWbcvbPaw/edit
Finding a good slotket adapter with the right jumpers is pretty hard though, but assuming you can, I highly recommend it.
Reply 14 of 37, by C0deHunter
I have decided to get this:
https://www.ebay.com/itm/HP-PII-233Mhz-512k-S … o1a8zY1&LH_FR=1
Reply 16 of 37, by H3nrik V!
That's nice, and being a Deschutes core, you must be able to almost run it on passive cooling at 133 MHz?
Reply 17 of 37, by zyga64
H3nrik V! wrote on 2021-04-15, 10:06:
Probably yes, but I only tested it at this speed, and that's all. No serial use, because for playing with early DOS I prefer my 486DX33 machine.
In fact it has original BIG heatsink which I don't know how to remove 😀 It looks exactly like this one. link
I rather prefer smaller cooling solution from original Intel BOXed processor (those are quiet).
At its original frequency (400Mhz) passive heatink is definitely not sufficient. It's too hot in my opinion, so small fan is attached in addition.
Good thing is - the motherboard I use (rather uncommon Totem P2BX with Intel BX chipset) has jumper for 66/100MHz so FSB can be changed on the fly (tested by me)..
Reply 18 of 37, by pixel_workbench
With good case airflow I run the P2-400 with its original gold-colored passive heatsink all day. I don't remember the temps ever going above 60C even under Prime95 stress test.
My Videos
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 19 of 37, by C0deHunter
I just placed an order for this!
Judging by the screenshots of this CPU, this would be good fit for my need
